Thread: Northstar TPS sensor part number?
Results 21 to 40 of 54
  1. #21 Re: Northstar TPS sensor part number?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    But it doesn't feel like it's spring loaded like a l67 one when I move it, it doesn't retract it's like free floating
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #22 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    you might not have installed it correctly
  3. #23 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Lol it's in my hand?
  4. #24 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    The part in the middle that hooks to the shaft on the throttle body is that spring loaded? Cuz mines not wondering if the springs broke or something
  5. #25 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    maybe I don't remember how it should look like
  6. #26 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I just went and looked at mine and it looks the same as yours
  7. #27 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Can you put your finger in the middle where my finger is and rotate it freely?
  8. #28 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    my finger doesn't really fit, but if it did then yes
  9. #29 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Okay is it all sloppy too? When you move it with your finger doesn't it stay where you moved it?
  10. #30 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I didn't actually try to spin it so I'm not sure
  11. #31 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Can you try?
  12. #32 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I will tomorrow, I'm falling asleep as we speak.
  13. #33 Re: Northstar TPS sensor part number?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I've had a N* on for 70k+ miles, never had a tps code
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  14. #34 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    it moves freely, but has stops so it shouldn't spin 360*
    Quote Originally Posted by Tonkin2000GT View Post
    Can you try?
  15. #35 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Okay thanks
  16. #36 Re: Northstar TPS sensor part number?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Try checking your wiring for the TPS, ensure that you're still getting the correct voltage (+5V iirc)
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  17. #37 Re: Northstar TPS sensor part number?
    hangover park IL
    far more often im finding intermittent issues on terminals/conn's
    the N*/lsx newer TPS's are internally floating (to self compensate for aaxial centerline alignment issues, it doesn't need a sporing, its the shaft that's sprung.
    gm made it more idiot proof than the old style tps's like the L67, which is basically similar to the design for early efi TPS's from back in the 80's
    problem is people still installed em wrong, so they dumbed it down a bit and saved $ at the same time.
    backprobe the tps and drivbe till it faults and see if the 5v drops out, then backprobe at the PCM and retest, if its wiring the pcm will see it but the tps conn probing wouldn't. if its the sensor, then both would show the same signal glitch
    ~James~ Psychotic Gearhead
  18. #38 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by Turbocharged400sbc View Post
    Thanks for the info my map sensor is reading all messed up so I ordered a new one i read online that the TPS could act up if it's not agreeing with the map sensor so I hope this fixes it. I just put a used 2 bar map on and didn't know if it worked and apparently it doesn't the reason why I put one on is because zzp had me set up on a single bar map when I top swapped. Scotty set me up with a gtp bin and we have been tuning then this started happening. Also I do have a mechanical autometer boost/vacuum gauge plumbed right between the LIM and map sensor that reads correctly.
  19. #39 Re: Northstar TPS sensor part number?
    hangover park IL
    Be careful how you Plumb your boost gauge I would not recommend off of the map sensor as the additional volume of air that must be moved during manifold air pressure changes is large enough to slow down and f***** up the map Reading speed.
    Temporarily remove it n retest
  20. #40 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    It read vacuum fine with the single bar map on my aeroforce just stopped at 0 because it was a single bar.
  1. Part Number
    By jwach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2016, 11:59 AM
  2. Looking for a 04+ part number
    By 2003 SSEi in forum General Tech Discussion
    Last Post: 12-13-2014, 10:30 AM
  3. Need GM part number for ECT sensor connectors
    By wild2crazy in forum General Tech Discussion
    Last Post: 10-24-2013, 08:36 PM
  4. MAF part number for 02 gtp
    By jonygtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2012, 04:44 PM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
