02 grand prix. The power mirror switch broke and I need to remove it. I tried pulling on it and twisting it. It still won't budge. It doesn't appear to have any tab on it either.
You have to remove the whole switch bezel from the door. Be very careful the little tab at the front can brake easy. Use a flat screw driver and pry up on the back of the bezel, the small end opposite of the mirror switch. The bezel will pop up and then pull up and back to take it, unplug the wires and you'll see a couple taps to take out the switch, be careful with those tabs too.
Yeah f*ck I broke that front tab on the bezel lol. Finally got the switch out though. Looks like a trip to the junkyard.
Does anyone know how to remove the window reveal on top of the drivers side door? It's the black piece that goes along around the top of the window and on the inside part of the piece it has like a rubber strip along the entire piece. The rubber strip on mine is cracking and coming apart. Someone else glued it but the glue is coming off. I have pics of the part I just don't know how to post them here. I'm on my phone
Ya every ones is cracked, you probably won't find good ones at the JY but you never know.
You have to unscrew that screw. Take the door panel off, take the 3 nuts off for the side mirror and take that off, and there will be another screw down that end somewhere
