Thread: 2004 GP Low Oil Level Light Problem
Results 1 to 5 of 5
  1. #1 2004 GP Low Oil Level Light Problem
    Jun 2016
    Horseheads,Ny
    Hello everyone I have a 2004 Grand Prix. My problem which im sure a lot of people have is problem that my low oil level light wont go off. I have replaced the sensor twice already and each time it worked great for a few days then the light is back on. Yes I made sure my oil was up an such. I have no idea what too do now. I most recently unplugged the sensor but still the message comes back on. does anyone have any idea what the problem might be?
  2. #2 Re: 2004 GP Low Oil Level Light Problem
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Why did you replace the sensor in the first place? A lot of sensors on these cars cannot be replaced with aftermarket options. It's best to stick with the original one, but if you can't, buy Delphi or AC-Delco. Otherwise expect problems.
  3. #3 Re: 2004 GP Low Oil Level Light Problem
    St. Louis
    Maybe check the wires going to the plug to be sure they aren't cracked/broken. Might give a false reading.
  4. #4 Re: 2004 GP Low Oil Level Light Problem
    Jun 2016
    Horseheads,Ny
    I have checked everything. I still don't have any luck with this. the message is still popping up even with the sensor unplug. I have a feeling its something internal or there is a wiring problem somewhere up the line. Does anyone have an idea on where the wires run too?
  5. #5 Re: 2004 GP Low Oil Level Light Problem
    Quincy, Mass
    I have this issue in my 04 Impala and it seems to be a common issue with them as well. Replaced the level sensor with a new ac delco one and no luck. I've been told by a very trustworthy mechanic and friend that I should take out the oil pressure spring in the oil filter adapter and clean out in there as it can actually be caused by a pressure issue. My pressure appears to be fine via my gauge but I plan to put in the high pressure kit from intense and a new oil pressure sensor and see if that helps. I have oil it's just annoying to see the light.
    No more GP 04 Impala SS Indy:
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. to all who have ever had low oil level light come on...
    By ddw350 in forum General Tech Discussion
    Last Post: 09-30-2013, 10:08 AM
  3. Low oil level light
    By 1slo03GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2012, 03:19 PM
  4. Low oil level AND oil pressure light
    By davidw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2011, 09:09 AM
  5. Oil Level Light problem likely the sending unit?
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 08:48 AM
