Thread: Steering Shaft
Results 1 to 5 of 5
  1. #1 Steering Shaft
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Think it's time to replace the intermediate shaft, is the any better than Dorman or the Dealer.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Steering Shaft
    Not really, they all end up doing the same thing.
    I have just taken them apart and added new grease and it works great.
  3. #3 Re: Steering Shaft
    Jan 2009
    ny
    Dealer replaced the original part on 4/22/10 and again 4/11/12 with part #19179923. They never used grease, but the part should last longer than 2 years. I figured since It had to removed to be greased, I might as well replace it. I was going to go with Dorman through Autozone, since they have a lifetime warranty. With a lifetime warranty I'll replace every two years, instead of greasing it. Maybe I'll purchase from Autozone, inspect the factory part and if grease can be use return the replacement to Autozone.
  4. #4 Re: Steering Shaft
    My sisters bonnieville had the recall/tsb or whatever done to it before we owned it and it still made noise and was like that for 2 more years. I removed it and re-greased the whole thing and hasn't been a problem in almost 2 years now.
    I like free repairs over buying a $50-80 part.
  5. #5 Re: Steering Shaft
    Jan 2009
    ny
    Thanks for the info
  1. Loose steering after replacing intermediate steering shaft on 06 GP GT
    By Tross901 in forum Other 3800 Powered Cars
    Last Post: 06-03-2015, 10:56 AM
  2. intermediate steering shaft
    By mstowe in forum Shops and Community Heroes
    Last Post: 10-08-2013, 07:02 PM
  3. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  4. Steering Intermediate Shaft
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2009, 12:22 AM
  5. Intermediate Steering Shaft.
    By bentendo92 in forum General Tech Discussion
    Last Post: 09-18-2008, 07:04 PM
