Thread: Dropping from a 3.4 to a 3.3 pulley
Results 1 to 19 of 19
  1. #1 Dropping from a 3.4 to a 3.3 pulley
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    So I had talked to you guys about having 0 KR with a 3.4 pulley and I was debating on getting a 3.3 to throw on you guys said it's safe the maf will adjust it. Well I just got my 3.3 today and went for a drive it's warm today like almost 80 and that's about as hot as it gets here my question is how long does it take for the maf to adjust? It was weird because I hammered on it and got a blip of .4 and .9 right off the bat then back to 0 real quick then I couldn't get it to register anymore kr after that and I drove around for a while hammering on it. I was at about 6psi to 7psi of boost on the 3.4 I'm running about 8psi now with the 3.3.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: Dropping from a 3.4 to a 3.3 pulley
    The MAF doesn't auto adjust to a boost pressure change, not sure who said that to you.
    Anything under 1º of knock is something I wouldn't even bat an eye at.
  3. #3 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    Okay a couple guys on here said it'll adjust from a .1 of a pulley drop I had a thread on it. Why do you think I had a blip of .4 and .9 from the first time I got on it? Then nothing after that kinda weird I was wondering if the computer was compensating for the air change from the .1 pulley drop? I have 15° of timing it's a can tune form zzp is that a decent amount?
  4. #4 Re: Dropping from a 3.4 to a 3.3 pulley
    you need to tune the maf if need be for a smaller pulley, 3.4 to a 3.3 should be ok. check your fuel trims and wide band if you got one to make sure its all in range still.
    its not gonna self learn.
  5. #5 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    My trims and everything seem about the same.
  6. #6 Re: Dropping from a 3.4 to a 3.3 pulley
    im selling my dhp soon if you want to start tuning.
  7. #7 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    How come? I don't know if it's worth it, it runs good the way it is.
  8. #8 Re: Dropping from a 3.4 to a 3.3 pulley
    Kemmerer, Wyoming
    I didn't know how ignorant I was until I started tuning, and I don't even tune much. about all I can do is a maf adjustment and mess with timing advance. the more you learn, the more you see how little you really know.
    Tuning will really help you.
  9. #9 Re: Dropping from a 3.4 to a 3.3 pulley
    im getting a upgraded dhp. its bought and paid for, just waiting for it to show up, then this one is getting posted for sale.
  10. #10 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    How much would you want? What can't it do that the upgraded one does? Can you use a tablet for the dhp? I just don't wanna F anything up and everyone tells me it's safe the way it is and I probably will hardly notice a difference once it's tuned so unless I intercool and drop more pulleys what's the point?
  11. #11 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    So if I only got a blip of .4 and .9 of kr once at about the same time should I leave the 3.3? How much kr is to much? Everyone says something different lol so anytime I've ever had kr is a quick blip I've never had it hold at a certain number is that normal?
  12. #12 Re: Dropping from a 3.4 to a 3.3 pulley
    the new one i got has a wideband port, the old one does not.
    if you mod a tuner is like a mod. if it will take more timing you can add to it, if the fuel trims go lean you can add fuel, and canned tunes blow.
    when you take a scan and adjust via the scan things turn up much better.
  13. #13 Re: Dropping from a 3.4 to a 3.3 pulley
    and it should work on a windows OS tablet. used laptops are pretty cheap. i got mine for 25 bucks off cl. all i use it for is tuning.
  14. #14 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    So do you think it'd run alot better with a tune? I just don't know enough to mess with it myself and I don't really know anyone that does stuff like this.
  15. #15 Re: Dropping from a 3.4 to a 3.3 pulley
    the reading mod does come into play lol a few headaches later you understand what your doing.
    im willing to help you out, ive tuned quite a few cars over e mail.
  16. #16 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    Pm'd
  17. #17 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    Are you getting any of my messages?
  18. #18 Re: Dropping from a 3.4 to a 3.3 pulley
    im not.
  19. #19 Re: Dropping from a 3.4 to a 3.3 pulley
    Jul 2015
    Jamestown, NY
    I think it's because I'm on tapa talk.
  1. Dropping pulley size, good idea?
    By pontiac98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2014, 09:25 PM
  2. dropping pulley size
    By Joseph Hegner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 09:57 PM
  3. Dropping a pulley size and fixing damage from deer
    By SleeperGS in forum General Tech Discussion
    Last Post: 12-31-2010, 01:18 PM
  4. Safely dropping my pulley size.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-30-2010, 09:08 AM
  5. Pulley dropping, got a question on belts
    By OH4CompG in forum General Tech Discussion
    Last Post: 10-29-2009, 06:46 PM
