Thread: DIY AC repair critique
Results 1 to 5 of 5
  1. #1 DIY AC repair critique
    Dec 2011
    MN
    Let me know if I did this right (2001 pontiac GP 3.8 NA GT)
    had leak in system, determine it was either the liquid line or suction line underneath the brake booster area, could hear hissing from that area.
    Did the do nothing option for a while then got my wife prego and she said either fix the AC or we buy a new car with one that works.
    Evac'd the system.
    Removed old liquid line, suction line and replaced with the drier/accumulator and replaced all orings I touched and used NAPA syl-glyde for lube of orings.
    Put nitrogen 100 psi test on system and soaped all fittings, no bubbles and pressure held steady for 2 hours.
    Pulled deep vacuum with robinair 5 cfm 2 stage for 1 hour and system went to -30" HG within 10-15 minutes. isolated system by closing gauge knobs and turning off pump.
    Left gauges on over 14 hour time frame and went from -30" HG to -29" HG, felt the system was tight enough to fill.
    Read label on driver shock tower (R-134a with dye, factory charged to 2.25lbs). Bought 3 cans of R134a, First can was 11oz of R134a, 1 oz of oil and .5 oz of drying agent. Second can was 11oz R134a with 1 oz of dye. Third can was striaght 12 oz of R134a.
    With system still in -30" HG I hooked up the first can and purged my charge line, then slowly opened the low side on the manifold. Car was running (idle) with AC on max with fan speed on #3 and all doors open. Followed directions on can and after about 5 minutes the compressor cycled on and sounded nice and smooth. Then added second can and so on to third can. Took almost an hour to add all the refrigerant, I went slowly by heating cans in engine bay and warming with hands to help fill system but every once and a while I had to tilt horizontal to slug refrigerant in, did it carefully though by watching my sight glass on the manifold gauge set.
    Was pretty cool outside (61F ambient) and center vent was dumping a consistent 35-38F degree air. drove for 20 miles and keep digital thermometer and never hesitated. Felt the liquid line after condensor and was hot and after orfice tube was cold.
    Let the car sit in the sun for a while with the windows up (increase load on evaporator (dry bulb only no humidity outside)) and turned on again. Low side pressure was between 25-30 PSI with the high side steady at 100 psi and the center vent 35F. Ambient temp was 62F ish with little to no humidity and interior car temp was around 80 ish.
    Waited a couple hours and pulled it back in the garage and inspected all lines and components with black light and found no traces of UV dye (even checked the Evap drain elbow and clean)
    Anywas - since I tried doing this DIY, how did I do? what mistakes did I make, let me know.
    My plan is to wait until we get a good 85F degree day and hook up the gauges again and measure the center vent temp but it has been pretty chilly here in MN.
    Tools used -
    Robinair 5 cfm 2 stage vacuum pump - bought
    CPS MA1234 working mans gauges for R134a - bought
    standard tools for removal and replace
    Nitrogen tank (had from snowmobile shock repair work)
    black light UV detection - bought.
  2. #2 Re: DIY AC repair critique
    GXP Level Member
    Mar 2015
    Tomball
    Sounds pretty good to me. I usually end up charging to about 45psi on the low side and 245psi in the high side, but it's hotter than hell down here and I usually have to do AC work when it's 95+ outside. I know my Park Ave had a variable compressor so when it was low demand the high side pressure was much lower, but when demand was high it would switch to higher differential pressures.
    Jeff
  3. #3 Re: DIY AC repair critique
    Dec 2011
    MN
    So interesting you mention that, do you know how the heck this works?
    I am assuming that it is looking at the liquid line pressure (via the sensor after the condensor but before the orifice tube) and varying some sort of valves on the compressor.
    Why don't they just install TXV's on these systems, so much easier to set up and operate way more efficient.
  4. #4 Re: DIY AC repair critique
    GXP Level Member
    Mar 2015
    Tomball
    I don't remember exactly, the only reason I even knew about it was that at idle the AC wouldn't keep up and I would have to get rolling before it would start to cool off. In traffic it was a bear. I started checking into it and I always had really low high side pressure (100-150 iirc) but my low side was around 45psi. I started reading up on it and there is a shuttle valve that basically makes the pump high or low displacement and would stick in the low displacement side. As I recall it was completely mechanically operated (no electronics involved) I looked into it and I would have needed to evacuate the system and then pull out and replace the valve in the rear of the compressor, but finding it was an issue and at that point it was easier just to replace the compressor itself. I am not an AC expert by no means I just work on them when I have to.... which seems to happen a little too often. Sorry not more help as that's about all I know about that system. I am not sure on when they stopped using them even. That car was a 97' and now I have an 05'GTP and haven't even looked into how it works or if it's different since it's been working great since I bought it a little over a year ago.
    Jeff
  5. #5 Re: DIY AC repair critique
    Dec 2011
    MN
    Found this video, it explains it very well
    https://www.youtube.com/watch?v=DPuYF0eNK6M
  1. 1998 GTP supercharger repair kits repair cost
    By SpecialK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2015, 10:49 AM
  2. Rim repair?
    By mteschGTP in forum Tires & Wheels
    Last Post: 10-07-2013, 11:32 AM
  3. Hud repair on 04+ help
    By Grandprix202 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2013, 07:56 AM
  4. Critique the build on our 3.8L SC
    By 4birdman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2011, 12:53 PM
  5. how can i repair this
    By sca555 in forum General Tech Discussion
    Last Post: 10-28-2010, 07:52 PM
