Thread: MAF Issues
Results 1 to 8 of 8
  1. #1 MAF Issues
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Ok, the car is a 1999 Buick regal that's been turbod. I'm running an lt1 maf and I had to extend the maf harness to run it.
    I Was doing some tuning today so I decided to mess with my afc 2.0. I plugged it in and turned the key to the on position. It lit up at first then just died. Now my maf isn't reading at all. I had the scanner hooked up and it was driving around at 0 hertz. I did get a code which was p0102. I'm really hoping that the signal wire for the maf just came loose. I'm stuck at work so I won't be able to test the stuff until later.
    Any ideas as to what happened?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: MAF Issues
    check the fuse box for the "ING" fuse. it should power the maf, you may have blown the fuse some how. code 102 is a low voltage code. so no power to it. wires or the fuse is my guess.
  3. #3 Re: MAF Issues
    Apr 2014
    South Haven, MI
    All 3 IGN fuses check out. The two big fuses and the mini fuse were fine.
  4. #4 Re: MAF Issues
    check the in car fuse box too? never know.
  5. #5 Re: MAF Issues
    Apr 2014
    South Haven, MI
    The scanner was showing 0 hertz while I was driving. Is that part of the same power issue?
  6. #6 Re: MAF Issues
    id think so.
    maybe you got the afc wired in wrong and its whats wrong. id take that off and re do the harness connections.
  7. #7 Re: MAF Issues
    Apr 2014
    South Haven, MI
    I extend the maf harness about a month ago. I plan on redoing it anyway. I hope that fixes it.
  8. #8 Re: MAF Issues
    Apr 2014
    South Haven, MI
    Solved it.
    It turns out it was the emissions 10 amp fuse in the Under hood fuse box.
  1. need help on two issues
    By paedbo in forum General Tech Discussion
    Last Post: 05-13-2014, 09:09 AM
  2. Abs issues?????
    By jewell83 in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2014, 10:11 PM
  3. few issues help!!!
    By Jory Johnson in forum General Grand Prix Discussion
    Last Post: 06-15-2012, 03:33 PM
  4. Odd abs issues
    By m1sterb0b in forum Brakes/Suspension/Chassis
    Last Post: 03-07-2011, 05:41 PM
  5. new guy with some issues
    By 85burbanator in forum Introductions/Noob Questions
    Last Post: 07-16-2010, 07:21 PM
