Thread: New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
Results 1 to 10 of 10
GeddyLee New HIDs installed and High... 08-07-2008, 01:38 PM
Zef_66 Re: New HIDs installed and... 08-07-2008, 03:07 PM
QwikGT Re: New HIDs installed and... 08-07-2008, 03:46 PM
GeddyLee Re: New HIDs installed and... 08-07-2008, 06:21 PM
QwikGT Re: New HIDs installed and... 08-07-2008, 07:02 PM
GeddyLee Re: New HIDs installed and... 08-08-2008, 12:56 PM
Zef_66 Re: New HIDs installed and... 08-08-2008, 02:13 PM
QwikGT Re: New HIDs installed and... 08-08-2008, 05:08 PM
JEFFSGTP Re: New HIDs installed and... 12-11-2008, 02:31 PM
stilltippin863 Re: New HIDs installed and... 01-29-2009, 07:26 PM
  1. #1 New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    St. Louis Mo.
    Ok I got a new HID kit off eBay. Its a really nice kit, I decided to go with the Slim digital ballast model with the 9007-2 HID low and Halogen high beam setup.
    The install was a breeze and they actually turn on the first time the lights come on. Unlike my craptastic WBody HIDs I use to have in my car. It was really direct plug and play with no splicing or slicing involved. HOWEVER, the order to which the high beam and low beams work are out of balance.
    Meaning that when I have high beam clicked on the steering column and you see the blue high beam indicator active, the HIDs light up and the foglights go out. And when you click the level on the steering column to goto low beam, the Halogen high beams and the foglights turn on and the HIDs go off.
    Does anyone have any clue as to why this is happening? I hope maybe BackInBlack will see this post as well and someone can chime in and help with this issue. Its not a major issue, but an annoying one.
    Here is the kit I purchased off eBay if anyone is interested in it. They have an awesome Rating and pretty decent customer service as far as I can tell given all the emails sent back and forth between me and them.
    eBay Motors: Xenon HID Conversion Kit Slim Ballast H1/H3/H4/H7/9006 (item 200242551282 end time Aug-03-08 12:22:01 PDT)
    Any help is appreciated. Thanks for listening.
    James Shafer
    St. Louis MO
  2. #2 Re: New HIDs installed and issues that need to be addressed
    PA
    From what I know, you need to pull two of the wires out of the connector and switch them. Not sure which ones or anything. But I know I read a post about it either her or CGP
    2001 GSE
  3. #3 Re: New HIDs installed and issues that need to be addressed
    May 2008
    staten island,NY
    i dont like the slim ballast because you still have to mount the resistor in front of it. anyways, the connectors have to be switched around on the ballast. they dont tell you which side goes in what so usually its hook it up see if it lights, then switch em up. the ones i bought off this group buy are pretty good ill take some pics when the sun goes down. hey geddy you ever watch Aqua Teen Hunger Force?
  4. #4 Re: New HIDs installed and issues that need to be addressed
    St. Louis Mo.
    Will it help I take pictures of the wiring to show you all to better guide me to which wires I need to change? Cause at this point I have no clue which wires you are referring to.
    James Shafer
    St. Louis MO
  5. #5 Re: New HIDs installed and issues that need to be addressed
    May 2008
    staten island,NY
    the wire from the light bulb to the ballast is crossed. turn the connector around and plug it back in. they don't key them right or wrong so it will fit both ways but one way doesn't work
  6. #6 Re: New HIDs installed and issues that need to be addressed
    St. Louis Mo.
    Ok thanks to Qwik I was able to figure out the problem. I didnt have to swich any wiring on the ballast, but I did have switch the wiring on the connector that lead to the factory plugin. It seems for whatever reason, the company had the High beam and Low beam wiring backwards. Here is a picture of the BEFORE and a diagram of what I had to do to undo the problem.
    Here are some more of the pictures of the HIDs and a little bit of the setup. The slim ballasts made hiding them easy. And unlike the WBody one's these puppies fire right up and dont flicker. Yeah it musta been a "ground issue."
    In this picture you can see the Halogen High beam and the HID Low Beam. Obviously the Halogen High Beam isn't going to be blind anyone, but at least now my car will pass state inspections cause it has High Beams again
    James Shafer
    St. Louis MO
  7. #7 Re: New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    PA
    Sweet. I just ordered a set, but not from the same people. But still from ebay. So I will see how they look when they arrive. Hopefully they work as well as yours!
    2001 GSE
  8. #8 Re: New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    May 2008
    staten island,NY
    i took the little halogen bulb off mine. ill just use my fogs to flash if necessary, glad i could help you out
  9. #9 Re: New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    Nov 2008
    Heaven, compared to HERE
    Cool...I think that is the infamous 9004/9007 issue...IIRC 9004's are backwards from 9007's I think BackinBlack brought it up in his HID thread.
  10. #10 Re: New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    Jan 2009
    frostproof,fl
    Ok i am haveing this same problem mine are also the 9007 bulbs on a 2000 grand marquis
    i bought this kit off ebay it is the slim ballast too
    eBay Motors: DIGITAL SLIM Bi-Xenon Hi/Lo HID Kit H4 9004 9007 H13 (item 220341278966 end time Jan-24-09 00:06:47 PST)
    my problem is
    when i turn the high beams on in side the car my lows come on when i turn on the lows my highs beams are on
    i already switched the wires and it did the same thing so i switched them back and same thing is there anything else i can do to fix this issue??? this is my first time on this web site and i do not get on here much so if anyone can help me please e-mail me at stilltippin863@msn.com thanks alot
  1. Sunroof issues
    By Mikel2k7 in forum General Tech Discussion
    Last Post: 06-28-2008, 11:27 AM
  2. Just bought her even though she has some issues...
    By heat in forum Visual/Body Modifications
    Last Post: 05-13-2008, 04:32 PM
  3. Supercharged issues?
    By lt1transam in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2008, 02:56 PM
  4. Which Hids
    By krippled in forum General Tech Discussion
    Last Post: 01-31-2008, 11:17 PM
