Thread: Can a Painless Performance (or stock) LS1 harness be modded to work for an L67 build?
Results 1 to 5 of 5
Sirayden Can a Painless Performance... 04-29-2016, 02:57 PM
Fivefingerdeathpunch Re: Can a Painless... 04-29-2016, 03:07 PM
Sirayden Re: Can a Painless... 04-30-2016, 07:47 PM
Turbocharged400sbc Re: Can a Painless... 05-01-2016, 12:58 AM
Fivefingerdeathpunch Re: Can a Painless... 05-01-2016, 04:57 PM
  1. #1 Can a Painless Performance (or stock) LS1 harness be modded to work for an L67 build?
    Oct 2014
    United States
    The reason I ask is because I can get a new one for a couple hundred bucks. I also have an HP Tuner Pro to mod the pcm though I haven't used it before.
    -Can the LS1 pcm be used? Can cylinders #7 and 8 be "tuned out" of it and the 6 cylinders can be fired in the right order?
    -I'm using a manual transmission so don't need to control an electronic transmission...just the engine.
    -Are the connectors about the same and sensor locations close enough so they don't need extensions? Don't want to have to chop this new harness to bits.
    Thanks for your help!
  2. #2 Re: Can a Painless Performance (or stock) LS1 harness be modded to work for an L67 bu
    To my knowledge you cannot use that computer. There is no way to have it setup for these cars.
    Some of the big changes are that the LS1 computers use a normal VE and MAF table to run the motor, 3800 computer are basically MAF only. Waste spark ignition system on a 3800 compared to a regular single coil pack. No real way to just disable two cylinders from firing and changing the firing order to get it to work.
    It's best to just find a 3800 computer and disable all the transmission related codes and it will run like normal. I'd suggest a 99-00 computer just to not deal with the cat tests that HPT can't disable.
  3. #3 Re: Can a Painless Performance (or stock) LS1 harness be modded to work for an L67 bu
    Oct 2014
    United States
    Thanks for the info, man. I appreciate it.
  4. #4 Re: Can a Painless Performance (or stock) LS1 harness be modded to work for an L67 bu
    hangover park IL
    98/99 fo lyfe
    00+ is the crap
  5. #5 Re: Can a Painless Performance (or stock) LS1 harness be modded to work for an L67 bu
    2001+ is the crap.
    My 2000 computer is the same as the 1999.
  1. Build or buy vacuum harness?
    By wmorrison65 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2015, 10:59 AM
  2. Cheap and Painless MP3 alternative
    By SlprGS in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2012, 10:42 AM
  3. 0-60 stock/modded gt/gtp
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-10-2011, 02:46 PM
