Thread: Northstar TPS sensor part number?
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Northstar TPS sensor part number?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Does anyone know what the part number is for the Northstar throttle body?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #2 Re: Northstar TPS sensor part number?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I would wait a few days before changing a north star tps. when I had my N* tb, I changed the TPS like 3 times. it would fix it temporarily and then the problem would come back and I would not do anything about it and it would go away. not sure really what the problem was.
  4. #4 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by SgtMarshal View Post
    What was your TPS doing?
  5. #5 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    the first time I was driving up a mountain with the cruise control on. the car downshifted, revved to 5000 rpm and stayed there until I turned off the cruise control and slowed down. other times I would just get a code for the TPS, and if I remember correctly it was P0121.
  6. #6 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    My cars doing the same thing all the sudden when me and Scotty are tuning my car so you never found out the problem?
  7. #7 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I never figured it out. I had problems off and on the whole time. I have an L67 throttle body on now. when I put the L67 TB on, I had a code for tps, but it cleared and hasn't come back in 6 months or so. I would give it a while and see if it goes away, but if not, just put the L67 back on. As much as I like the throttle response of the N*, the hassle wasn't worth it.
  8. #8 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    I've had the N* on for 2 years haven't had a problem untill I started tuning today. I cleared the code and it came back after 50 miles or so and started doing the same crap.
  9. #9 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    usually when it would start acting up, I would shut the car off for a minute and when I started driving again it would be fine.
  10. #10 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    I cleared the code with the dhp and it's fine for a while anyways how weird. I can't imagine were the only ones with the problem.
  11. #11 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I've heard a few of the guys around say they didn't like the N*
  12. #12 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    The throttle response is night and day better plus I have inlet and outlet porting so it matches up perfect with my inlet it kinda sucks
  13. #13 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    How long did you have yours on before it started acting retarded?
  14. #14 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Thanks for the part number do you have a N*? Or have had any problems?
  15. #15 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    3 or 4 months. maybe just be patient and see if it sorts itself out. the problem usually went away after the car was turned off.
  16. #16 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    So buying a new TPS is a waste of money huh? Couldn't even notice a difference?
  17. #17 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I changed the tps like 3 or 4 times and the problem always came back eventually
  18. #18 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    Okay good to know thanks man.
  19. #19 Re: Northstar TPS sensor part number?
    Jul 2015
    Jamestown, NY
    I took my TPS off and was yours like all loose like the part in the middle of the sensor that hooks to the Northstar? It's all wobbly and you can freely move it with your finger.
  20. #20 Re: Northstar TPS sensor part number?
    Kemmerer, Wyoming
    I think that's normal, the middle part is just a spring
  1. Part Number
    By jwach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2016, 11:59 AM
  2. Looking for a 04+ part number
    By 2003 SSEi in forum General Tech Discussion
    Last Post: 12-13-2014, 10:30 AM
  3. Need GM part number for ECT sensor connectors
    By wild2crazy in forum General Tech Discussion
    Last Post: 10-24-2013, 08:36 PM
  4. MAF part number for 02 gtp
    By jonygtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2012, 04:44 PM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
