Thread: Headers without deleting cat
Results 1 to 17 of 17
  1. #1 Headers without deleting cat
    Apr 2013
    New Jersey
    Is there a header set up that doesn't remove the catalytic converter?
    Headers are almost universally recommended over the powerlog + downpipe combo for someone who plans to mod substantially. That said, I live in a state that has emissions testing, and need this car to be legal (it's a daily driver as well). Here are my questions:
    1. Is there a header set up that, without any modification, doesn't remove the cat?
    2. Is it possible to combine a header with a different downpipe to avoid removing the cat, and is this something I could do myself, without welding?
    I assume if neither of these are possible, I'd have to take the car to a shop to get the headers installed with a cat. I have a 2002 gtp if that makes a difference.
    Thanks!
  2. #2 Re: Headers without deleting cat
    Willoughby, Ohio
    1. companies like ZZP may offer an option to add a cat with their headers, but usually when we buy headers and need a cat, we buy the magnaflow high flow 3inch cat
    2. any set of headers can be cut and modded, just need sum skillz
  3. #3 Re: Headers without deleting cat
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    The Speed Daddy's I got have a space in the down pipe to either put in your cat (typically the Mangaflow 3" like CTK said) or the supplied ~12" section of 3" pipe with two band clamps.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #4 Re: Headers without deleting cat
    Nov 2011
    NY
    I got my 3" down pipe with hi flow cat from ZZP...
    I installed Ceramic coated Pacesetter headers.
  5. #5 Re: Headers without deleting cat
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Will the high flow cat not mess with the second O2 sensor readings and throw a code?
  6. #6 Re: Headers without deleting cat
    Nov 2011
    NY
    Nope... No codes, everything installed and worked nicely.
    I may take the cat out eventually, but for now it's in and stays.
  7. #7 Re: Headers without deleting cat
    SE Level Member khornocker's Avatar
    Jan 2016
    Corydon, Indiana
    id like to bump this old thread if I may.
    I'm getting ready to install speed daddy headers on my 2005 GTP. My state does not require emissions testing so im thinking about not installing a catalytic converter back on my car. what kind of CEL am I going to see after my header install? and how can I get the future CEL to go away?
    also, what are the pros and cons when deleting the cats.
  8. #8 Re: Headers without deleting cat
    GXP Level Member
    Mar 2015
    Tomball
    For 05 your going to have a hard time with the cat test that happens. But using a tuner you can set the codes to not report. I am about to install SD headers and a 3" Cat on my car, we'll see how it works.
    Jeff
  9. #9 Re: Headers without deleting cat
    i was just looking at 04 and 05 bins in tiny tuner, i see no cat test listed.
    your best to get a cat. they fit in place of the mid pipe in the down pipe of sd headers just fine. i got a 3 inch hi flow, your conna want something closer to stock cell count to keep the pcm happy.
    ive seen a guy here, he cut off and opened up the in and lets of the stock cat and welded the 3 inch pipes to it. iirc hes in ca and needed the factory cat.
    in your case its likely the best route to go due to the pcm using the rear o2 sensor.
  10. #10 Re: Headers without deleting cat
    I wouldn't doubt it if the cat test is there but you can't turn it off.
    My 06 sierra had a cat test that could not be disabled if you left the rear o2 sensor's unplugged, but if you kept them plugged in and turned off the error codes it was all gravy. Just a weird thing with those pcm's.
  11. #11 Re: Headers without deleting cat
    Jan 2016
    Corydon, Indiana
    Do you think this cat would work.
    MagnaFlow® 54959 - Federal Catalytic Converter (3" Center Inlet / 3" Center Outlet more details on - http://www.carid.com/magnaflow/catal...FdgNgQodxfoIww
  12. #12 Re: Headers without deleting cat
    I think that's the one I run but my cat codes are deleted..
    04 Comp G.
  13. #13 Re: Headers without deleting cat
    Jan 2016
    Corydon, Indiana
    Quote Originally Posted by J57ltr View Post
    Jeff
    What brand cat are you installing
  14. #14 Re: Headers without deleting cat
    GXP Level Member
    Mar 2015
    Tomball
    This is the one I bought, I won't be installing it for a couple of weeks.
    http://m.ebay.com/itm/435300-3-quot-...=1234050622004
    Jeff
  15. #15 Re: Headers without deleting cat
    paid 20 shipped iirc for this one off ebay.
  16. #16 Re: Headers without deleting cat
    GXP Level Member
    Mar 2015
    Tomball
    That one is cheaper but I opted for the longer one since it said OBD2 compliant for what that's worth.
  17. #17 Re: Headers without deleting cat
    Jan 2016
    Corydon, Indiana
    I found a flow master 415300. 3" high flow 300 cell.
    Do you think 300 cell will be ok or should I look for a 400
  1. Deleting a thread?
    By JesseBranham in forum Forum Bugs/Suggestions
    Last Post: 11-04-2012, 09:05 PM
  2. Deleting po449
    By papaspanky in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2012, 06:57 AM
  3. about deleting codes
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2011, 01:03 PM
  4. deleting DRL
    By tod1d in forum General Tech Discussion
    Last Post: 06-17-2008, 10:12 PM
