Thread: Grounding wire on ICM
Results 1 to 5 of 5
  1. #1 Grounding wire on ICM
    Sep 2015
    IL
    does this wire get sandwiched in the back of strut bracket between the head and bracket, or does it go in front sandwiched between the bracket and flange of the bolt? This is on the ICM, lowest bolt that screws in (not the two studs)
  2. #2 Re: Grounding wire on ICM
    There's a bolt that is next to it.
    Here ya go
  3. #3 Re: Grounding wire on ICM
    Sep 2015
    IL
    Awesome, thanks
  4. #4 Re: Grounding wire on ICM
    I've worked on a couple of these things. If you ever need a picture or advice... lol
  5. #5 Re: Grounding wire on ICM
    Sep 2015
    IL
    Yeah just did my first lim job, almost ready to fire the car up and see what happens. Unfortunately I happened to break one of the stupid ports on the vacuum manifold on top of the supercharger, I think its the one that goes to the actuator (short, hard tube). I ordered a new one but in the meantime is the car driveable with this broken? I'm guessing I just won't get any boost. I feel dumb cuz I didn't even need to try and take it off.
  1. Grounding Two Amplifiers
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2013, 08:04 PM
  2. Grounding Kit
    By Dee23 in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2012, 12:32 AM
  3. Stereo grounding
    By mikejon in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2011, 03:53 PM
  4. Grounding both amps?
    By Magnaflow GP in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2010, 03:52 PM
  5. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
