Thread: HVAC vacuum diagram? 98 GTP
Results 1 to 4 of 4
  1. #1 HVAC vacuum diagram? 98 GTP
    Jan 2016
    Orlando
    Hey guys. New owner of a 98 GTP. Trying to get the HVAC controls situated since air only blows out of the defrost. Thinking it's a vacuum line somewhere. Are there any of those diagrams around or maybe someone could point me in the right direction to look? Any help would be greatly appreciated.
  2. #2 Re: HVAC vacuum diagram? 98 GTP
    If you look at this pic, the top of the supercharger is a vacuum tree there are 3 lines, one goes to the brake booster, one goes to the bypass solenoid and the middle one that says to acsry, is the one you need to trace and find the leak in. It is not fun as it goes around behind the battery then into the wire harness before going into the vehicle.
  3. #3 Re: HVAC vacuum diagram? 98 GTP
    Jan 2016
    Orlando
    Everything top side looked good but found a broken tab where I circled. Would that make any difference?
  4. #4 Re: HVAC vacuum diagram? 98 GTP
    Quote Originally Posted by Quickbird144 View Post
    It might, but I think you would see other issues.
    So you checked out the vac line that is in the wire loom all the way to where it goes into the wire harness?
  1. 04+ hvac wiring diagram
    By vandezand in forum General Tech Discussion
    Last Post: 03-12-2016, 09:01 PM
  2. Where should I tie into for vacuum for the HVAC?
    By traildog in forum General Tech Discussion
    Last Post: 02-05-2014, 05:52 PM
  3. 2000 GT NON-SC Vacuum Diagram anyone?
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2013, 11:45 AM
  4. Vacuum diagram for top swap
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2012, 02:51 PM
  5. Need a vacuum diagram for this car ..
    By turboLude in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-25-2012, 06:22 PM
