Flexpipies are flex pipes, just make sure you get a double walled or tripled walled and you'll be fine. The one Scotty linked will work fine and is inexpensive.
They have triple wall? Are they stiffer any disadvantages?
I thought I seen them before but ehh I might be wrong.. Regardless stop overthinking this lol grab the one Scotty linked and enjoy
ive not seen a triple wall, double wall is fine. the new one is much stiffer then the old single wall i replaced.
ScottyDoggs is it possible to cut the old flex off my headers and keep the overall length the same with this flex you linked? Or would you think I would have to get a flex with 2" of pipe welded on each end to make it easer for the guy welding it?
whats there is about 6 inches. so it should be a direct swap. if you gain clearance its a plus. i know i did. id not add any pipe to it.
only thing id think about is a v band on both sides of the flex. that way you dont even have to un bolt the dp if the flex fails down the road. you just cut the two v bands off and re weld them on the new flex.
So your saying if it ends up being up to like what a inch shorter or so it'll still fit fine? How much shorter did yours end up being? I'm not to concerned about the new one going bad I don't drive the car alot it's a summer car because it's been painted and I have ALOT of money in it. Everything is literally new lol I drive it like 6 months out of the year I only put a 1,000 miles on it last summer.
its fine a bit shorter, things still line up fine.
i keep forgetting to take a pic of how it sits now.
Okay thanks man
