Thread: 2005 Keyless entry quit working (Reciever location?)
Results 1 to 19 of 19
  1. #1 2005 Keyless entry quit working (Reciever location?)
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    2005 grand prix comp g. All the sudden both remotes quit working all together (new batteries, tested signal, both were good). Wondering where the receiver is located so I can see about replacing it. after googling it, it looks as if it is either part of the body control module or its own unit (neither were very clearly explained.). I saw it might have been located in my trunk, but it was no where to be found. Is it buried in the dash somewhere?
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  2. #2 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    It's in the trunk, if you climb in and look in the middle of the deck just reach your hand in there and there should be a module, if your car has a 5 button dic then there will be two modules one is your rke the other is your compass. If I remember correctly the rke module would be on the passenger side when you reach your hand in there
    Sent from my iPod touch using Tapatalk
  3. #3 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    So it should be right by the monsoon amp?
  4. #4 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    Yes
  5. #5 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    Ok I thought I had looked up there but might have missed it, will check next chance I get
  6. #6 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    Alright
  7. #7 Re: 2005 Keyless entry quit working (Reciever location?)
    GXP Level Member
    Mar 2015
    Tomball
    I'm pretty sure 05 is built into the BCM as there is nothing in my trunk and and I have also read it's in the BCM n 04+.
    Jeff
  8. #8 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    I drive an 05
  9. #9 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    And it's in my trunk
  10. #10 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    so I don't see my receiver anywhere in here
    // 2005 Comp G
  11. #11 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    It'll be this or there is another module that clips in like it one is your compass the other is the rke module
  12. #12 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    oh so its on the top side of the deck? access from the back seats im assuming?
    // 2005 Comp G
  13. #13 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    I don't have the amp so I access it through the the hole that's there I guess you'd have to go at it like you were changing a speaker?
  14. #14 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    will take a look at it, could probably pull the amp if needed, will keep you updated
    // 2005 Comp G
  15. #15 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    Alright
  16. #16 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    So I was able to pull this out of my trunk deck. two modules up there, the other one said "compass" on it. assuming this is the RKE module
    // 2005 Comp G
  17. #17 Re: 2005 Keyless entry quit working (Reciever location?)
    Aug 2015
    Virginia
    I believe that is it haha
  18. #18 Re: 2005 Keyless entry quit working (Reciever location?)
    Nov 2010
    Maryville, MO
    haha good! so do I just need to buy a new one now? or where is the best place to get one
    // 2005 Comp G
  19. #19 Re: 2005 Keyless entry quit working (Reciever location?)
    Apr 2019
    St. Charles
    did it fix it?
  1. keyless entry quit working
    By screechingdemon in forum Audio, Security & Visual Electronics
    Last Post: 08-11-2013, 01:40 AM
  2. So my keyless entry stopped working... and other questions
    By HaterSlayer in forum General Tech Discussion
    Last Post: 10-13-2012, 02:49 PM
  3. Keyless Entry not working after replacing battery!
    By wagatlng in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2011, 10:43 PM
  4. alarm and keyless entry not working
    By jcs in forum Audio, Security & Visual Electronics
    Last Post: 04-07-2010, 11:20 AM
  5. keyless entry not working???
    By 04GTPCOMPG in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2009, 07:31 AM
