Thread: Power window cable
Results 1 to 7 of 7
  1. #1 Power window cable
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Figures these things always happen when it cold out...lol.
    Noticed my passenger rear window would not go all the way up the other day. Removed the door panel and the motor seems to be working correctly, but the cable is not where it belongs.
    The cable appears to be in good condtion. I'm thinking the easiest way is to remove the regulator from the car?
    It looks like there was a "how to" at some point but the links no longer work.
    Thanks!!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: Power window cable
    you need to replace the whole regulator. its just a few bolts. pretty simple really.
  3. #3 Re: Power window cable
    Toledo, Ohio
    Thanks!! I did all 4 window regulators on an older Sunfire...and it wasn't a tough job. At least the Prixs are bolted in....the sunfire i had to drill out rivets.
    Any recommended replacement? I see AC Delco on amazon for 101.
    http://www.amazon.com/ACDelco-11A14-...regulator+rear
  4. #4 Re: Power window cable
    its a coin toss how long anything but oem will last. some have good luck with the cheaper ones, some dont.
    ive noticed my back window is moving around in the track, thats a sign to be ready to replace it.
  5. #5 Re: Power window cable
    GrandPrix Junkie
    St. Louis
    While the regulator is out make sure to lubricate the felt window guides with some graphite spray. It will keep the glass from sticking and messing up your new regulator. And clean the glass inside and out as well. It seems like the smallest little bit of resistance on these causes them to struggle and break. Once you replace enough of them you should be able to do one door in 30 min or less panel off to panel on, lol..
    I went with the Delco one last time for my drivers window and it seems to be better than the cheaper ones. Just make sure you test the window operation BEFORE you put the panel back on as sometimes the motors are wired backwards and the switch will work in reverse. If so, just pop the wires out of the harness and reverse them. All you need is a good pick.
  6. #6 Re: Power window cable
    Jan 2021
    Ohio
    Reverse the wires at the motor?
  7. #7 Re: Power window cable
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    I was able to get the cable assembly with the lift without a motor for $20 off of eBay, its probably cheap - but the motor is what's important, IMO. *shrugs*
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  1. Cable on window regulator comes off [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2015, 04:44 PM
  2. Drivers 2 door window cable broke -_-
    By DrSnazzy in forum General Grand Prix Discussion
    Last Post: 03-25-2013, 03:08 PM
  3. Another window problem...L/F cable issue
    By Pittman06 in forum General Tech Discussion
    Last Post: 10-31-2009, 09:33 AM
  4. Re-running Window Regulator Cable..?
    By m0ng00se in forum General Tech Discussion
    Last Post: 03-30-2009, 03:20 PM
  5. Window cable?? 98 Grand Prix GT 4 door
    By markh in forum General Tech Discussion
    Last Post: 10-13-2008, 05:36 AM
