Thread: 3.3" or 3.4" pulley on E85
Results 1 to 13 of 13
  1. #1 3.3" or 3.4" pulley on E85
    SE Level Member MM06GT's Avatar
    Jan 2013
    SF Bay Area
    Hey guys, I'm looking to to convert over to the corn juice of E85. The question have is what size pulley should I buy if I go with the 50lb injectors from Will at Overkill Motorsports? My current mods are in my sig.
    Silver 06 GrandPrix GT: K&N cai//3" catless DP//SS plog//Rear ported Mani//AL xp 104s//180* TS//ZZP 10.5 wires//TB HS//ZZP 3.2" MPS//E85//50lb injectors//1.9 YT rr//90lb sprs//Impala DP brakes//AF scan gauge//Mini AFR//BLK 18x9 saleen replicas//Overkilled.
  2. #2 Re: 3.3" or 3.4" pulley on E85
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    You underestimate the powers of E85.....2.8-3.0 range
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: 3.3" or 3.4" pulley on E85
    Jul 2012
    Chicago
    Yup. Start with the 3.0
    -Carl
  4. #4 Re: 3.3" or 3.4" pulley on E85
    Jan 2013
    SF Bay Area
    Really that small?!?! Lol, Sorry, I don't mean to question you guys, but I thought it was only like 2 sizes you can drop. Should I wait for what size too drop down to after I get another tune?
  5. #5 Re: 3.3" or 3.4" pulley on E85
    Sep 2015
    flint
    If overkills current tune is right.. you could drop in 50s, e85, and a 3.0 pulle and go. Obviously you'll need to make sure the fuel pump is ready to party.
    Doesnt run 9s
  6. #6 Re: 3.3" or 3.4" pulley on E85
    Jan 2013
    SF Bay Area
    Quote Originally Posted by notdarkhorizon View Post
    Alright, I'm in, I'll start with a 3.2" pulley first to see how much my trans hates me lol, then go smaller(knowing my trans will eventually give up the ghost). Thanks for info fellas'.
  7. #7 Re: 3.3" or 3.4" pulley on E85
    Apr 2011
    Columbus, OH
    When you get a tune have trans tables modified.....drop pan and do a trans service and add a shift kit while you're at it. Help prolong the life of the transmission. Driving style will be the biggest factor.
  8. #8 Re: 3.3" or 3.4" pulley on E85
    Jan 2013
    SF Bay Area
    I know these are separate questions, but I just read Frosty's defacto on E85 again(great sticky info) and....
    1) What fuel pump would be best for an 06 on E85? And....
    2) Is it possible to change the fuel filter on 06 with out taking it to the stealership to get rapped in labor costs? Can I change it on my own?
  9. #9 Re: 3.3" or 3.4" pulley on E85
    Jan 2013
    SF Bay Area
    Quote Originally Posted by GMR Badass View Post
    Will this shift kit work? http://www.amazon.com/Transgo-T84167.../dp/B008XO9ATC
    Or is there more too it? The car is my DD as far as normal driving goes, but my plan was to try and get in some runs at Sonoma Raceway before the end of the season.
  10. #10 Re: 3.3" or 3.4" pulley on E85
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    You should not need a new fuel pump just yet with your current mod list and 3.0-3.2 pulley. Just a fuel pump rewire and maybe a new high flow filter should do the trick just fine.
    Also, with a very similar setup (check my sig) I was able to run a 3.1 pulley with little to no knock on E85. Starting with a 3.2 is a not a bad idea. scan with aeroforce, and go from there. Watch your KR at part throttle and throttle increases as well as WOT. I noticed more trouble dialing in my part throttle and quick throttle pushes than I did at WOT on my E85 setup.
    cheers!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  11. #11 Re: 3.3" or 3.4" pulley on E85
    Jan 2013
    SF Bay Area
    Quote Originally Posted by 97AutoXVette View Post
    cheers!
    Thanks 97AutoXVette, yeah my mods will almost be the same as yours except for the L67 to L32, are you on a stock trans with no problems with that 3.1" pulley?
  12. #12 Re: 3.3" or 3.4" pulley on E85
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by MM06GT View Post
    Ahh, I missed that part about the GT vs. GTP model. And correct, no trans issues. I did do a TON of weight reduction to make it easier on the trans (car was pretty gutted. no interior really, stereo delete, etc.) But, trans was doing just fine.
    2002 GTP sedan:
  13. #13 Re: 3.3" or 3.4" pulley on E85
    Jan 2013
    SF Bay Area
    Hey guys, just an update, I just recently installed my 50lb injectors and 3.2" pulley and the car is a completely different animal. I wish I had switched to E85 sooner. Oh, and you guys were right, I'm getting 0 KR on this 3.2" pulley so 2.8-3.0 would be about right.
  1. 3.5 pulley, TB Spacer, PLOG, other "go fast" goodies
    By GTPlzz in forum Wanted To Buy - Parts
    Last Post: 02-13-2014, 04:27 PM
  2. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
