Thread: l32 lim gasket
Results 1 to 4 of 4
  1. #1 l32 lim gasket
    Sep 2015
    IL
    https://www.rockauto.com/catalog/mor...nid=491&jpid=5
    Rock Auto sends me to this link for the LIM gasket, pn 89017825
    But then another write-up on a different forum a guy says that the pn for the l32 is 89017816, which is this:
    https://www.rockauto.com/catalog/moreinfo.php?pk=2005610&jnid=494&jpid=1
    Looks the same, but the second one comes with a 3rd gasket that I don't see with the first. Is this critical? Which gasket set should I use?
  2. #2 Re: l32 lim gasket
    get the magnum gasket set. it comes with more stuff and costs less. its what im using. make sure its the metal set. you can tell cause its silver.
  3. #3 Re: l32 lim gasket
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    The little third one is for a coolant block off passage on the end of the LIM underneath the throttle body. If it's not leaking, don't replace it.
  4. #4 Re: l32 lim gasket
    Apr 2015
    http://www.gmforum.com/attachments/b...k-img_6656.jpg
    It's for the little rectangle plate with the dome in it.
  1. Head gasket problem, 25 miles on new gasket
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2014, 04:25 PM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
