Thread: 04+ power drop harness
Results 1 to 12 of 12
  1. #1 04+ power drop harness
    Dec 2013
    laporte mn
    Does anyone know where the power drop harness is in an 04 + car?
    Thanks
  2. #2 Re: 04+ power drop harness
    GXP Level Member
    Mar 2015
    Tomball
    What are you referring to?
  3. #3 Re: 04+ power drop harness
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    the only thing that comes to mind is maybe a harness that is behind the glovebox...seems there is a kit you can buy to tap into that
  4. #4 Re: 04+ power drop harness
    seem a pic of one behind the glove box, had a hige tag on it, said power drop. not kidding.
    cant find it, buy a add a fuse.
  5. #5 Re: 04+ power drop harness
    Dec 2013
    laporte mn
    Already have an add a fuse on radio fuse. But I can't find an key on circuit that stays on for my meth controller
  6. #6 Re: 04+ power drop harness
    wiper fuse is what im tapped into. its a key on only fuse. hell i got two gauges and my amp power on wire to it.
  7. #7 Re: 04+ power drop harness
    Dec 2013
    laporte mn
    If I plug more than one add a fuse into it the second gauge always stays on no matter what
  8. #8 Re: 04+ power drop harness
    i dont understand what you mean there.
  9. #9 Re: 04+ power drop harness
    Dec 2013
    laporte mn
    I have an add a fuse on the radio fuse. I have my aeroforce plugged into that. Then I have an add a fuse on top of that first add a fuse and that is what my meth controller is plugged into. When I shut the car off the aeroforce shuts off, the radio shuts off, but the meth controller stays on
  10. #10 Re: 04+ power drop harness
    i dont think you can piggy back a add a fuse. but why its still got power makes no sense.
    take the one for the meth and run it in the wiper fuse.
  11. #11 Re: 04+ power drop harness
    Dec 2013
    laporte mn
    Ok. I tried that and after a couple minutes that fuse goes dead
  12. #12 Re: 04+ power drop harness
    you running a relay to the pump?
  1. Power Drop Harness location
    By rhenuset in forum 04+ Specifics
    Last Post: 09-23-2015, 06:04 PM
  2. ZZP Power Drop Harness
    By KoldAsIce in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2014, 11:54 PM
  3. power drop harness
    By lilmidge12 in forum Introductions/Noob Questions
    Last Post: 02-23-2014, 10:18 PM
  4. Replies: 0
    Last Post: 01-01-2012, 01:24 AM
  5. power drop
    By Toasty in forum General Tech Discussion
    Last Post: 03-18-2008, 07:36 PM
