Thread: intercooler setups
Results 1 to 8 of 8
  1. #1 intercooler setups
    What would be an ideal intercooler setup for running a 3.0 pulley, 1.9 rockers, full headers, 3'' exhaust, p&p gen 3,180 thermostate, autolite 104's, ls1 tb, cai, and obviously a tune. Is it hard to made a fmic setup or just go with a short stack intercooler?
  2. #2 Re: intercooler setups
    Hoffman/Schaumburg, IL
    for a 3.0 and no cam, I'd say a Full sized IC, stage 2 or 3(if that even still exsists)... FMIC are usualy only effective on turbo cars, cause they need the air after the (insert F/I device of your choice here), and before the intake manifold, which is impossible on our cars with the M90 as it is
  3. #3 Re: intercooler setups
    Anybody get any links of some good intercooler setups. Where can get a good intercooler that won't empty the wallet.
  4. #4 Re: intercooler setups
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by robahr24 View Post
    By a used stg 2 gen 3. Either find a full kit or the core. Look in the for sale section here and on clubgp.com or other forums. ZZP's fmhe is the best heat exchanger for our cars right now, you can find them elsewhere but you know this is designed around our cars - ZZ Performance
    You can buy the hoses and fittings later at a hardware store. You may want to look into different IC pumps and see what is best for your setup, mine came with a pump so I never really looked too much at them.
    Edit: lol, i concur with bio... left my reply box up and didnt submit until 20 min. later...
  5. #5 Re: intercooler setups
    get a ZZP stage 2 setup. it is nearly the best one you can get, best bang for the buck by far. get the biggest front mount heat exchanger you can get. might be good to look into the new ones from ZZP that are like the frozen boost ones.
    this will cost you around $1000 though..
  6. #6 Re: intercooler setups
    So I can pretty much get this one,
    ZZ Performance.
    Is there anything I can make for cheaper?
  7. #7 Re: intercooler setups
    the only thing you might be able to get cheaper in this case is if you go with a cheaper front mount heat exchanger. just get a VW one off ebay or something and that will work nicely. it just wont be the best setup you can have. you can also buy a pump and all the hosing for cheaper if you know how to shop around.
    the core is the part youre never going to get around buying a good one. used are fine as long as they work and are complete.
  8. #8 Re: intercooler setups
    SE Level Member kamper98's Avatar
    Mandan, North Dakota
    Since we are talking about fmhe's, which one would you think is the best for just performance, frozenboost or zzp's? i currently run the version #3 fmhe that came with the stage 2 and am going to upgrade front mounts this spring. Any ideas or numbers to help?
    S2 I/C, ZZP FMHE, 3.0", TOGS, FWI, 3" DP, 42.5 lb. injectors, 1.9's, 104's, Fuel pump rewire, Flowmasters, ZZP machined intake, N*, LQ4, ZZP Fuel Logs w/ PRJ regulator, AN Fuel lines, Ported I/O Gen 3, F-body 12in Brakes, 8 rib, HPTuner
    Car SOLD
  1. Wideband setups, tell me about yours...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 09-17-2009, 12:38 PM
  2. different exhust setups
    By cobraz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-19-2008, 03:37 AM
  3. TB for Turbo setups
    By japslpr in forum Turbo
    Last Post: 09-03-2008, 07:06 AM
  4. SS intercooler ?'s
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2008, 12:11 AM
  5. which intercooler ???
    By DunriteDiesel in forum Off Topic Discussion
    Last Post: 06-15-2008, 10:40 PM
