I'm looking to upgrade my rear lateral links on my 2000 gtp it's literally the last part of the suspension that is stock are bmr lateral links worth the extra money? I have pretty good suspension parts on the car like kyb agx struts, mooge parts like tie rod ends, lower control arms, sway bar links front and rear, gm performance bigger front and rear sway bars, zzp front and rear strut tower braces etc. So my car is stock height because of where I live and the roads with that being said I don't need additional adjustment with these rear lateral links from what I can see the forward lateral bars are fixed and the rearward is adjustable correct? I noticed bmr sells them just like that does anyone have any part numbers? I'd like to go with the bmr fixed lateral bars and the adjustable ones on each side like factory is this the way to go?
