Thread: '01 wont start, won't turn over
Results 1 to 8 of 8
  1. #1 '01 wont start, won't turn over
    Dec 2015
    Kansas
    Hi folks, as you can see this is my first post. There are some problems with my wifes GP with a normal 3800. When the key is turned to "run" everything normal lights up on the dash. When it's on "start" nothing happens except all the dash lights go off. Took off and tested the starter, it was OK. I put a voltmeter on the little terminal on the starter (the one that activates the magnet) and it showed anywhere from 0.25 to 0.75 volts with the key in start. I replaced the key cylinder. The security light stayed on, but I did the procedure where you leave it in "run" for 10 minutes then try to start it x3 (takes 30 minutes). The security light went away. Replaced the starter anyway, and it still wouldn't crank over. Voltage was still below 1.0 volt at the starter.
    What would you do next? Tomorrow someone is coming by with a code reader to try some diagnostics.
  2. #2 Re: '01 wont start, won't turn over
    Check your ground cable to starter is my first guess.
  3. #3 Re: '01 wont start, won't turn over
    Clean all known grounds.
  4. #4 Re: '01 wont start, won't turn over
    St. Louis
    Also remove and clean all battery terminals, and make sure they are tight when you get them back on. My 00 GT did this to me and it was a slightly loose cable at the battery.
  5. #5 Re: '01 wont start, won't turn over
    SE Level Member Rod2003GT's Avatar
    Sep 2015
    CT
    Had similar issues with a Sunfire and a Grand Am. Both were bad ICM's.
    2003 Pontiac Grand Prix GT
  6. #6 Re: '01 wont start, won't turn over
    Dec 2015
    Kansas
    It was the ignition switch. Not the tumbler but the switch that the tumbler fits in to.
  7. #7 Re: '01 wont start, won't turn over
    SE Level Member tyjarr's Avatar
    Apr 2016
    I am having the exact problem in my 98 gtp. What fixed it?
    Sent from my SM-N910V using Tapatalk
  8. #8 Re: '01 wont start, won't turn over
    St. Louis
    Dude, read the post right above yours. The OP stated that it was the ignition switch.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. AC Fan wont turn on
    By kaminski347 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2011, 10:41 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. 97 GP GT ignition key wont turn back after start...
    By AREED in forum General Tech Discussion
    Last Post: 12-23-2010, 09:07 AM
