Thread: serpentine belt
Results 1 to 8 of 8
  1. #1 serpentine belt
    SE Level Member keenan00gtp's Avatar
    Oct 2008
    Iowa
    i need to get my belts back on. in my car i cant loosen the alternator to get the belt over it. any tricks?
    so far: borla catback exhaust, audio swap.
    waiting for warmer temps
  2. #2 Re: serpentine belt
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    why would you loosen the alternator, you just have to push the tensioner down with a 15mm wrench. (i think its 15mm anyway from what i remember)
  3. #3 Re: serpentine belt
    Feb 2008
    Umm, you're not supposed to loosen the alternator to get the belt on!
    There is a belt tensioner that is self adjusting. You just have to use the correct tool (15mm wrench or Serpentine belt tool) to pull it back which allows sufficient room to get the belt on.
    Tip: The belt goes on the alternator last!
    Let us know how it goes!!
  4. #4 Re: serpentine belt
    Oct 2008
    Iowa
    im pushing down on the tensioner pulley bolt with all my weight and its not budging. push it straight down right?
  5. #5 Re: serpentine belt
    Feb 2008
    Quote Originally Posted by keenan00gtp View Post
    Turn the bolt on the pulley as if you were trying to tighten it......it will then move the whole assembly.
  6. #6 Re: serpentine belt
    Dec 2008
    London, Ontario
    yeah pretend your'e trying to tighten it, and when it moves down use your other hand to roll the belt onto the alt pulley. Its still going to be a tight fit with the tensioner all the way down, but it will work. Its easier with 2 people for me.
  7. #7 Re: serpentine belt
    Dec 2008
    London, Ontario
    if it doesnt move your tensioner is screwed.
  8. #8 Re: serpentine belt
    Oct 2008
    Iowa
    acting like your tightening it worked like a charm. you were right about it being tight too. you just need a extra set of hands.
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. serpentine tensioner
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 08:20 PM
  3. Supercharger Belt Came Off!!
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 03:34 AM
  4. pulley belt from zzp
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 03:09 PM
