Thread: Replacing a speed sensor, where are they located?
Results 1 to 4 of 4
  1. #1 Replacing a speed sensor, where are they located?
    Jan 2009
    Waterloo, IA
    Just recently i had problems with my 1997 grand prix going into what i believe is limp mode. A friend told me that its probably my speed sensor and im trying to figure out where they are located. Also i was wondering if the abs/tire pressure/ trac control sensor located on the front wheels act as a speed sensor also??
  2. #2 Re: Replacing a speed sensor, where are they located?
    Oklahoma
    Welcome to the community. Moved this to the correct area.
  3. #3 Re: Replacing a speed sensor, where are they located?
    Barksdale AFB, LA
    The vehicle speed sensor (VSS) is located on the differential cover. Passenger side of the car, right where the passenger side axle connects to the transmission.
    The ABS sensors are only used for the ABS and traction control systems. They don't measure the vehicle's speed. Instead they monitor individual wheel speeds so the system can compare them to each other.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Replacing a speed sensor, where are they located?
    Jan 2009
    Waterloo, IA
    Hey thank you for the quick reply, i hope to get the scanner hooked up to my car soon to verify the problem. Would the abs sensor lead to my car going into limp mode like that. Because i have also had my abs/trac control/low tire pressure lights come on and i know its because of the sensor on the tire, just havent gotten around to fixing that yet...........
  1. Vehicle Speed Sensor????
    By Luminary in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2022, 01:38 PM
  2. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  3. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  4. replacing the OEM radiator
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2008, 06:09 PM
