Thread: 2001 gp gt. shake at 45mph..
Results 1 to 8 of 8
  1. #1 2001 gp gt. shake at 45mph..
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
    Hey guys i need some imputs, my gt has a pretty good shake around 40-45 mph. Its not in the steering wheel either. I have replaced control arms/ball joints, tie rods, both wheel bearings, front brakes and rotors, new tires and rims.. Now what else could it be? Cv axles?.. Inner tie rods?... It has a slight hum when idling in drive but goes away when i turn, the cv boots all seem good and not leaking, and there is no clicking yet.. HELP lol winter is on the way to michigan!!
  2. #2 Re: 2001 gp gt. shake at 45mph..
    Is the shake while on the gas or off the gas??
  3. #3 Re: 2001 gp gt. shake at 45mph..
    Oct 2015
    allendale michigan
    On the gas only!!
  4. #4 Re: 2001 gp gt. shake at 45mph..
    axle if its gone when coasting. and vibrates when on the gas.
  5. #5 Re: 2001 gp gt. shake at 45mph..
    Oct 2015
    allendale michigan
    If i do one, do i have to do both??
  6. #6 Re: 2001 gp gt. shake at 45mph..
    you should be able to feel what side its coming from. change that side.
  7. #7 Re: 2001 gp gt. shake at 45mph..
    Oct 2015
    allendale michigan
    I hear its common for the passenger to go bad first because they are longer...i feel the shake only when i accelerate. I feel it all over lol the whole car get shaking
  8. #8 Re: 2001 gp gt. shake at 45mph..
    have someone else drove your car and you ride in the pass sieat, you should be able to tell if its worse or not from each side.
    either one can go bad, or they could both be bad. rare as that seems to be.
    if you get under the car and watch the axle as someone shifts in from d to r you should hear a click, or see the two shafts not move at the same time, like on both sides of the cv joint.
    if one of the boots are torn up and slug grease all over thats the one to change first.
  1. shimmy now not a shake
    By jhintz in forum Introductions/Noob Questions
    Last Post: 05-19-2013, 03:27 PM
  2. 99 Buick Regal Surging under light acceleration at 35mph(rarely) or 45mph(randomly)
    By vtechkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2013, 06:43 AM
  3. Rpms drop under slow acceleration at 45mph
    By Bluemagic in forum General Tech Discussion
    Last Post: 04-29-2012, 07:31 PM
  4. HID Shake
    By NewBoost1997 in forum General Tech Discussion
    Last Post: 09-21-2011, 10:49 AM
  5. Loud noise above 45mph
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-09-2008, 10:03 PM
