Thread: Compass Module Wiring
Results 1 to 8 of 8
  1. #1 Compass Module Wiring
    Ohio
    Hey everyone,
    So I did a 3 to 5 button DIC swap probably 2 years ago and I have just been dragging my feet hooking up the compass module. I finally pulled everything apart and the wire is not there. Apparently I have some weird 05 GP Base that doesn't have the wire since everyone else says it's right there takes 2 minutes and your done. I have followed the wire down the driver side by the seat belt and it isn't there. Has anyone had this problem and is there a way to solve it? Here is a picture of the wiring.
  2. #2 Re: Compass Module Wiring
    Ohio
    Bump
  3. #3 Re: Compass Module Wiring
    Canada
    Same thing on my 2005 GP. I thought it would be there but it wasn't.
  4. #4 Re: Compass Module Wiring
    Omaha, NE
    I would go to the junkyard and pull the whole wiring harness from the decklid to the 5 button DIC.
    This should give you a rough idea of what you need.
  5. #5 Re: Compass Module Wiring
    GXP Level Member
    Mar 2015
    Tomball
    There's nothing in my 05 GTP either, so some cars are not wired for it even though everything else works when i
    changed from a 3 button to 5 button.
  6. #6 Compass Module Wiring
    Quincy, Mass
    06 base didn't have it either
    Has the temp wiring and I just had to add a sensor
    No more GP 04 Impala SS Indy:
  7. #7 Re: Compass Module Wiring
    Nov 2020
    Michigan
    I have an 06 base and I just did the 3 to 5 button swap. I bought the compass module and everything. I dont have the wiring at the deck lid, has anyone found a solution or did i buy the compass module for nothing?
  8. #8 Re: Compass Module Wiring
    Sep 2022
    Indiana
    The wire harness your looking for is located in the middle just right of the body control module not the right side near seat belt
  1. 04+ compass module info
    By jteske88 in forum Audio, Security & Visual Electronics
    Last Post: 08-28-2017, 09:50 AM
  2. 05 GP compass module help
    By Poseidon215 in forum General Tech Discussion
    Last Post: 05-24-2011, 05:04 PM
