My new to me 02 GTP is starting to have the rocker panel trim on the bottom of the door curl and come loose. Obviously it appears the double sided tape has failed/is failing. I've heard the 3M super strength stuff is good to reattach it. What can be done about the slight curling on the end? Heat gun and straighten it out? Also where can I find replacement clips? Mine look busted.
