Thread: Anybody move the battery to the trunk?
Results 1 to 6 of 6
  1. #1 Anybody move the battery to the trunk?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    My 05 Magnum has the battery located under the trunk floor by the compact spare....designed that way from the factory to improve the F/R weight bias. The Magnum has a "traditional" drivetrain layout, longitudinally mounted V8, auto transmission and RWD, so weight and balance is good. Moving the battery to the trunk makes it even better.
    FWD cars like the GP are hopelessly unbalanced with all of the weight above the front wheels, would moving the battery to the trunk have any measurable effect? Anybody tried it?
  2. #2 Re: Anybody move the battery to the trunk?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Moving 40 pounds couldn't make that much of a difference unless you were already trying to do some kind of race weight stuff
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: Anybody move the battery to the trunk?
    SWPA
    Considering FWDs need all the weight they can get over the front wheels moving the battery to the back is counterintuitive.
  4. #4 Re: Anybody move the battery to the trunk?
    Dec 2008
    ****'s Creek
    For traction, yes, considering that the front end lifts at launch. I was thinking more in terms of handling, taking that 40 lbs that sits ahead of the front wheels at the outside corner, and moving it inboard and rearward. Any amount of weight you can redistribute like this will make the car more nimble, but I'm not sure if the cost/effort are worth the results here.
  5. #5 Re: Anybody move the battery to the trunk?
    SWPA
    A Grand Prix is still going to be 3600 lbs, and still going to be nose heavy, and is never going to be nimble.
    If you want a nimble car get a Honda, or a BRZ,
  6. #6 Re: Anybody move the battery to the trunk?
    I moved it, but not for weight transfer.. More for I got tired of slamming my knuckles anytime I needed to either pull the battery or change a belt and I wanted the space to mount a IC reservoir there when the time came
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  1. Dead battery, no amp draw and battery tests fine
    By pontiac98 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2016, 09:44 PM
  2. How to remove/move battery to trunk GXP/GTP/GT
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 12-27-2013, 01:06 PM
  3. Replies: 12
    Last Post: 11-18-2013, 04:43 AM
  4. easiest way to move battery to trunk?
    By z3r0 in forum General Tech Discussion
    Last Post: 08-12-2011, 11:37 PM
  5. run the power cable from battery to trunk - FINISHED!! PICS!
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2009, 04:17 PM
