On my 00 gp gt the car will just turn over it will fire for like 2 seconds . Also all the dash lights flash when key is in ignition the fuel pump relay just sits there clicks any ideas?
theres a cap on the fuel rail, front of the engine, take it off, and push the pin inside with the key to run, gas should spray out with good pressure.
if nothing comes out or very little, your fuel pump took a dump.
you hear it priming? the pump that is?
you check for fuel pressure? just cause its new dont mean its good still. if you touched it, test it. aka it was the last thing you touched right?
yep..i've had plenty of "new" parts go bad shortly after install ... last one was an ac delco upstream O2 sensor. lasted 2 weeks and threw a code.
check the relay cause they can fail. swap it with the one next to it. its the same.
if that dont fix it open up the trap door and double check the wires if you had to cut the old plug and put a new one on the new pump like i just had to do.
