Thread: Need help finding Turbo rebuild kit or replacement turbo!
Results 1 to 2 of 2
  1. #1 Need help finding Turbo rebuild kit or replacement turbo!
    Jan 2015
    ohio
    1990 Pontiac Grand Prix McLaren 3.1L LG5 turbo v6.
    Link to engine and turbo info:
    http://www.v6z24.com/specs/31turbo
    This link is to a rebuild kit, Will this work? If not, what will?
    http://gpopshop.com/t2-t25-and-t28-rebild-kits/
    (Should I go dynamic or carbon seal?)
    More info about my turbo:
    ASC Part Number: V24X82467BXXX
    Manufacture: Garrett AiResearch
    Version: TB02528
    Cooling: Water and Oil
    Lubrication oil flow: 1.2 L/m SAE 30, 90Degrees C, 2.75 Bar
    Bearing: Floating sleeve
    Turbo Complete Part number: 465939-2X
    CHRA Number: 431876-29
    Compressor housing casting number: M24
    Compressor A/R: .80
    Compressor wheel trim: 70
    Compressor wheel diameter Ind/Exd: 1.69”/2.02”
    Compressor flow: 29 lbs/Min
    Turbine housing casting number: M4
    Turbine A/R: .68
    Turbine wheel trim: 62
    Turbine wheel diameter: 1.64”/2.09”
    Wastegate: Internal, vacuum/pressure actuated
  2. #2 Re: Need help finding Turbo rebuild kit or replacement turbo!
    hangover park IL
    try the real TGP guys on the more turbo grand prix centered forum www.w-body.com
    www.w*-*body.com remove the asterisks (just in case cgp still sensors links
    ~James~ Psychotic Gearhead
  1. HELP! Need replacement turbo!
    By GHOSTOWLGRID in forum General Grand Prix Discussion
    Last Post: 06-21-2015, 04:21 PM
  2. Replies: 324
    Last Post: 12-05-2014, 04:19 PM
  3. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
