Thread: looking for opinions.
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 88
  1. #1 looking for opinions.
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    i bought two of these hood scoops to put on my 2000 GTP , thinking it would lower under the hood temps and help with heat soak. i planned on cutting the hood and making them functional. the way i see it they could be used as ram air or cowl induction , but wouldn't fully serve either purpose . they'd sit to far from the windshield given the layout of where you can cut the hood and of course it wouldn't be a true ram air since it won't directly feed the intake filter.
    my problem is i can't decide on if i'd like how it looks. i got 2 to sit side by side. these are bolt on style so it's just a matter of drilling 4 bolts holes , but i'm looking for function so i would be cutting out holes in the hood. once that's done there's no going back if i don't like it , it's buy a new hood.
    so give me your thoughts. already got em primed and have the car paint and clear coat, but i've been holding off painting because i could use the paint elsewhere on the car if i decide not to do it.
    here's the scoops. they are 15 L x 11.25 W X 1.75 H
    http://www.racecomposites.com/mini2bolt.htm
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  2. #2 Re: looking for opinions.
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Those look similar to the front vents on the SD hood for these cars. It might look ok. Any pictures of them sitting on the car for a better idea? And are you going to mold them to the hood too?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: looking for opinions.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Honestly, I don't like the look of them. If you could've, you should've gone for Special Edition heat extractors or a hood with them already built in. The ones you have listed above look like something from a 5th generation GP. But this is just my opinion. If you like them, go for it.
  4. #4 Re: looking for opinions.
    Jan 2014
    AR
    I think they would stand out visually as being a universal add-on. On a race car, sure. On a mild street car, meh. I pass.
    The function would not be unlike the 40th anni GP's hood. They called those heat extractors and there was a rain tray underneath to keep water off important stuff. The idea of letting heat out just over the blower makes sense to me but calling them vents rather than scoops would take some getting used to for me.
  5. #5 Re: looking for opinions.
    Dec 2014
    Maryland
    Quote Originally Posted by SomeDudeAtHome View Post
    no these are bolt on only. they have a rubber gasket as you can see in the pic to seal them. that's why i got them , they were cheap $25 each, but they are fiberglass not plastic , and they are easy to install. i made cardboard templates to tape on the hood to drill the holes then cut inside the bolt holes and remove what i want of the hood skin. just can't decide if i wanna do it.
  6. #6 Re: looking for opinions.
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I'd save the paint for other places and then save up for a "real" hood.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  7. #7 Re: looking for opinions.
    leave the stock hood alone......
  8. #8 Re: looking for opinions.
    Dec 2014
    Maryland
    Quote Originally Posted by idrivejunk View Post
    the passengers side cutout would be over most of the SC blower so it should let some heat out when sitting still and push the hot air out under the car when moving. running an open cone , i thought maybe it might help a little with air intake temps. honestly i don't like the looks of the "inferno" ram air hood or the F1 hood, but i do like the other one .
  9. #9 Re: looking for opinions.
    Dec 2014
    Maryland
    personally i think this is the best looking hood i've seen for the GP...
  10. #10 Re: looking for opinions.
    Donating Users seventone's Avatar
    Mar 2013
    midwest
    no scoops, save up for a hood.
    1997 Black GTP Coupe | 1997 Black GTP Coupe | 2001 Silver GTP Coupe | 2001 Red GTP Coupe
  11. #11 Re: looking for opinions.
    Dec 2014
    Maryland
    Quote Originally Posted by seventone View Post
    but i don't really like the after market hoods and there's not much to choose from , SD...nope...F1..nope..WS6...hell no... the GTX hood is the only one i'd consider . i'd like something subtle , that's why i got the smallest ones i could find.
  12. #12 Re: looking for opinions.
    Mar 2013
    midwest
    A GTX hood is the way to go. i got lucky thanks to Black99gtx in the for sale area.
  13. #13 Re: looking for opinions.
    Those scoops will look like asshole.
  14. #14 Re: looking for opinions.
    Dec 2014
    Maryland
    Quote Originally Posted by Slick2500 View Post
    they ain't scoops...they are heat extractors ...
  15. #15 Re: looking for opinions.
    GXP Level Member
    Mar 2015
    Tomball
    So are the vents in the fenders functional on the GXP? I'm guessing the GTX is the brand of hood?
    i think I would have to see the scoop on the car to make a statement, but if what I think it looks too old school for a GP.
    Jeff
  16. #16 Re: looking for opinions.
    Jul 2015
    Quote Originally Posted by EHB View Post
    Dude this hood is legit.
    Sent from my SM-G920V using Tapatalk
  17. #17 Re: looking for opinions.
    Apr 2015
    Be straight up lol.
  18. #18 Re: looking for opinions.
    Buffalo
    I have a ram air plenum for my MPD hood that I can't use. If you decide to make some holes in your hood , let me know
  19. #19 Re: looking for opinions.
    Dec 2014
    Maryland
    Quote Originally Posted by cvilla690 View Post
    you can buy that scoop from the same place i got mine for 70 bucks . i'm sure it'll cost a pretty penny to have it molded to the hood. unless of course you have body work skills..
    http://www.racecomposites.com/ss.htm
  20. #20 Re: looking for opinions.
    Jul 2015
    Thanks man. Honestly I like it a lot. I'll have to get ahold of a good extra hood so I don't ruin mine lol. I'd like to do it myself.
  1. Need some opinions
    By Asinity in forum General Grand Prix Discussion
    Last Post: 12-11-2012, 01:24 AM
  2. Going cam'd...need opinions.
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2012, 03:15 AM
  3. Opinions on these??
    By 2dee11 in forum Tires & Wheels
    Last Post: 10-08-2012, 11:14 PM
  4. I Need Opinions
    By Hawkins97 in forum Off Topic Discussion
    Last Post: 04-06-2011, 05:14 PM
  5. Mod Opinions
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2009, 06:36 PM
