Thread: Will KYB Adjustable struts fix my problem? 245/45/18 tire
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Antioch, IL
    stick the jack underneath by the wheel where the trailing arm is and jack it up high you will see where it hits
    2009 Challenger SRT8
    Expert at being gay.
  2. #22 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    you won't be able to simulate a big bump with you and a friend pushing down on the car.
    rolling the fenders is easy so long as you use heat and take your time. i've done it many times with a heat gun and a rubber mallet. in fact i still start out rolling fenders this way and then i switch to the roller after i get it moved a decent amount.
  3. #23 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by silenthaven View Post
    Lowering will help the car not rub? And wouldnt I would have seen that lip touching the tire when i bounced the back? Quite a pricey job to not really know for sure...
    I did not say lowering will not make it rub. I said this so you can give the car a better stance. Rolling the fenders is a must if you are going to lower.
    Exactly.
  4. #24 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    Quote Originally Posted by ITHURTZ View Post
    So I jacked the car up to see the tire does eventually touch fender. It surprises me with gap I have I would bottom out that much to actually rub over freeway bumps. Leads me to believe my struts and or springs are going bad Unless this is typical?
  5. #25 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Apr 2015
    Columbus, OH
    Lol @ thread
    Top Swapped 01 Imp
  1. KYB AGX Adjustable Struts
    By rvnwlf in forum Brakes/Suspension/Chassis
    Last Post: 05-27-2012, 10:41 PM
  2. Problem installing new front struts
    By Mnasrv in forum General Tech Discussion
    Last Post: 12-29-2011, 03:32 PM
  3. the problem is tires or struts??
    By spider4 in forum General Tech Discussion
    Last Post: 11-19-2011, 02:48 PM
