Thread: Finalized LIM gasket plans
Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 273
  1. #41 Re: Finalized LIM gasket plans
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Oh and does the UIM need it too?
  2. #42 Re: Finalized LIM gasket plans
    Apr 2015
    I found the jar Scotty posted above for $8 at Advanced which is just down the street, I'll go with that.
  3. #43 Re: Finalized LIM gasket plans
    one with pfte is best. and only the lower intake bolts as they go into the coolant ports of the heads, why they pool up around the bolts, its coolant seeping past the threads.
  4. #44 Re: Finalized LIM gasket plans
    Be sure to clean the threads in the bolts too.
    I always let everything sit in the bucket of Chemdip for a bit. Makes life a lot easier. Then just spray them off with brake cleaner.
  5. #45 Re: Finalized LIM gasket plans
    Apr 2015
    Got it, thanks. I think I have all I need. Once everything is off, drain the oil and rinse the valley with oil. Use thread SEALANT on the LIM bolts after cleaning the threads. Once everything is back together, fill the car up with oil and coolant.
  6. #46 Re: Finalized LIM gasket plans
    Apr 2015
    In your "procedure" you didn't put down a dab of RTV before the LIM gaskets. Do a dab before and a dab after in each corner.
    Scott.. the o-rings to replace the coolant elbow ones are in the LIM kit. However.. most first timers are going to bust an elbow taking them out. Even if they are metal, especially if they were rtv'd in.
    I didn't read closely.. make sure you use pipe sealant on the LIM bolts.
    On the UIM bolts... use 89 inch lbs. Do not go over and as you torque them ...watch the ear that you are torquing at. If you see it turning white where it attaches to the UIM, stop right there. I've seen people break off those ears.. it's easy enough to do.
    Search on my name and "ea sy" without the space. You'll find plenty of info on various things that may be very helpful. Pics included.
    What is the ear?
  7. #47 Re: Finalized LIM gasket plans
    drain coolant first, (remove lower hose from engine) dog bones off rock engine back and fourth till no more coolant comes out the lower hose inlet on the timing cover. then lift the lim off level. so you dont leak any coolant into the engine. key is you dont want coolant in there at all if a avoidable.
    some one said something about a shop vac on blow to help clear the lim too. via the t stat hole.
    ff to 18:45 watch this asshole just let the lim spill into the engine. dont lift it off the way he does.
  8. #48 Re: Finalized LIM gasket plans
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    that's my video scott ...
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  9. #49 Re: Finalized LIM gasket plans
    no its not lol. i sure hope its not
  10. #50 Re: Finalized LIM gasket plans
    Dec 2014
    Maryland
    fooled ya ...
  11. #51 Re: Finalized LIM gasket plans
    whew!!! cause i pissed of one guy by posting his vid not knowing it lol
  12. #52 Re: Finalized LIM gasket plans
    Dec 2014
    Maryland
    Quote Originally Posted by ScottyDoggs View Post
    F'em if they can't take a joke..and if the video sucked, F'em for not be able to handle the truff !!
  13. #53 Re: Finalized LIM gasket plans
    the vid was good, but he stuttered and muttered through the whole vid. like took for ever to get to the point lol
    i mean if it was my vid id have deleted it and then started over and let no one hear me talk in circles like that lol
  14. #54 Re: Finalized LIM gasket plans
    Apr 2015
    Is it noticable when coolant goes down? Like will you hear it or see it or something? I mean wouldn't some still be in the coolant ports that stop at the LIM? Through the thermostat (I'm not taking it out, just the hose off), coolant elbow areas, and coolant ports are the only way coolant can escape. So if youre careful in those areas, shouldn't you be ok, especially around the coolant ports?
  15. #55 Re: Finalized LIM gasket plans
    do like ive told you idk how many times, and nothing should spill.
    theres a lip in the coolant ports that will hold back whats left inside the lim, but only if its held level. you'll see coolant if you spill any.
    always best to do a oil change tho. unless your 100% sure you leaked no coolant in the engine like i was.
  16. #56 Re: Finalized LIM gasket plans
    Apr 2015
    And you're only 100% sure if you drain 75% of the coolant. The video I watched on YT, the guy bought a Dorman LIM and what a POS it was. Half a gallon of coolant leaked in his crank case. Aftermarket parts like that aren't easy to get right.
  17. #57 Re: Finalized LIM gasket plans
    Dec 2014
    Maryland
    dude just go ahead and poor some into the engine and get it over with ...it's just an oil change...lol
  18. #58 Re: Finalized LIM gasket plans
    Apr 2015
    And if you pull the LIM out to the left, the little remaining coolant should stop at the T-Stat and not drip down.
  19. #59 Re: Finalized LIM gasket plans
    Apr 2015
    Quote Originally Posted by EHB View Post
    Dude, I changed my oil <400 miles ago, I'll do anything to avoid changing it again.
  20. #60 Re: Finalized LIM gasket plans
    Dec 2014
    Maryland
    better safe than sorry
  1. Help With Mod Plans
    By Konvinced89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2015, 10:27 PM
  2. my plans
    By BlackGT97 in forum Off Topic Discussion
    Last Post: 08-10-2011, 12:36 AM
  3. HELP!!! Big Plans...
    By m17davis in forum General Tech Discussion
    Last Post: 10-22-2010, 04:16 PM
  4. MY PLANS for the GT
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 10-28-2009, 11:47 AM
  5. Some new plans for the car.
    By 2000GTP in forum Off Topic Discussion
    Last Post: 10-22-2009, 12:03 AM
