Thread: Finalized LIM gasket plans
Page 2 of 14 FirstFirst 123412 ... LastLast
Results 21 to 40 of 273
  1. #21 Re: Finalized LIM gasket plans
    Quote Originally Posted by Impala131 View Post
    I should have been more detailed. 1 bolt for the idler, 2 bolts for the P/S pump, 4 bolts for the WP pulley, and 8 bolts for the water pump itself. Scrape off old gasket and put new one on. Thread sealant on WP bolts. Easy peace of mind.
    this guy dont need any extra bolts removed at this time, if you cant tell yet lol that pump can sit till it leaks. if its next week so be it. let him learn one job at a time.
  2. #22 Re: Finalized LIM gasket plans
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by ScottyDoggs View Post
    I will defer to your wisdom Scotty.... just trying to save the guy some time in the long run since he's already opening the cooling system.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #23 Re: Finalized LIM gasket plans
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Thanks for understanding lol.
  4. #24 Re: Finalized LIM gasket plans
    seems like a nice enough guy, but clearly hes new to wrenching. so the dont fix whats not broken rule comes into play for him.
    just imagine the fight he'd have getting the p/s pump back on.......one thing at a time.
  5. #25 Re: Finalized LIM gasket plans
    Apr 2015
    Yeah, it's hard enough checking the damn P/S fluid. Removing the pump itself seems like an impossible task lol.
  6. #26 Re: Finalized LIM gasket plans
    removal is easy lol its getting it back on when its gonna fight. but if the alt bracket is off its much easier to see wtf your doing.
    but your leaving that on too remember, you loosen up the 3 bolts a 1/4 inch each so it will let the bracket move just enough to get the rear valve cover off.
  7. #27 Re: Finalized LIM gasket plans
    Apr 2015
    Oh yeah. Anything else than needs to come off for getting the VC off?
  8. #28 Re: Finalized LIM gasket plans
    dont think you n/a guys got much covering the rear cover if any thing.
    the alt bracket just touches the cover, take a peek at it, its not a big deal.
  9. #29 Re: Finalized LIM gasket plans
    Apr 2015
    Ok. I think the engine cover mount curls up over the VC too so I think that has to come out too.
  10. #30 Re: Finalized LIM gasket plans
    whats a engine cover? i never owned one...
    that thing should be the least of your worries lol
  11. #31 Re: Finalized LIM gasket plans
    Apr 2015
    I don't have one either, but there's a tab on the back of the cover that slides in a bracket in the back, which curls over the VC.
  12. #32 Re: Finalized LIM gasket plans
    not sure how it fastens on there. i never owned on and im sc'ed.
  13. #33 Re: Finalized LIM gasket plans
    In your "procedure" you didn't put down a dab of RTV before the LIM gaskets. Do a dab before and a dab after in each corner.
    Scott.. the o-rings to replace the coolant elbow ones are in the LIM kit. However.. most first timers are going to bust an elbow taking them out. Even if they are metal, especially if they were rtv'd in.
    I didn't read closely.. make sure you use pipe sealant on the LIM bolts.
    On the UIM bolts... use 89 inch lbs. Do not go over and as you torque them ...watch the ear that you are torquing at. If you see it turning white where it attaches to the UIM, stop right there. I've seen people break off those ears.. it's easy enough to do.
    Search on my name and "ea sy" without the space. You'll find plenty of info on various things that may be very helpful. Pics included.
  14. #34 Re: Finalized LIM gasket plans
    Apr 2015
    I was just gonna torque the LIM bolts dry with no thread sealant at 14ft lb.
  15. #35 Re: Finalized LIM gasket plans
    Apr 2015
    And I had on there, 4 dabs of RTV without end seals on, and 4 more with end seals on. Are there any other places RTV needs to go?
  16. #36 Re: Finalized LIM gasket plans
    use thread sealant on the lim bolts or they leak coolant. clean them first, then new sealant, then tq em down.
    the rtv you got it right.
  17. #37 Re: Finalized LIM gasket plans
    Apr 2015
    So then clean the bolts with say Brake Cleaner and then put a dab of thread locker on?
  18. #38 Re: Finalized LIM gasket plans
    jesus stop slow down read. clean em with a wire brush, you'll see why, or get as much of the old crap off the threads. then use thread sealant, same stuff plumbers use to seal pipe threads.
    this little jar costs like 6 bucks or so, over the last 5 years its 1/2 gone now, maybe more. you have water pump bolts that need this sealant too. along with a few other in the timing cover.
  19. #39 Re: Finalized LIM gasket plans
    Buffalo
    Yeah. Wire wheel the bolts to get the sealant off and you can clean em with brake cleaner too
    i used
    http://m.advanceautoparts.com/mt/sho...ontent=general
    but yeah it's good to 450 and it was left over from my head studs. So I doubt you will need a high temp rating like that
  20. #40 Re: Finalized LIM gasket plans
    Apr 2015
    Will any thread sealant do or does it have to be a specific kind?
  1. Help With Mod Plans
    By Konvinced89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2015, 10:27 PM
  2. my plans
    By BlackGT97 in forum Off Topic Discussion
    Last Post: 08-10-2011, 12:36 AM
  3. HELP!!! Big Plans...
    By m17davis in forum General Tech Discussion
    Last Post: 10-22-2010, 04:16 PM
  4. MY PLANS for the GT
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 10-28-2009, 11:47 AM
  5. Some new plans for the car.
    By 2000GTP in forum Off Topic Discussion
    Last Post: 10-22-2009, 12:03 AM
