Thread: Finalized LIM gasket plans
Page 14 of 14 FirstFirst ... 4121314
Results 261 to 273 of 273
  1. #261 Re: Finalized LIM gasket plans
    after parking in the same spot for 5 years i had made a 3 foot round stain in the parking lot.
    new engine is leak free is so damn nice now i tell ya.
  2. #262 Re: Finalized LIM gasket plans
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by EJOUIE View Post
    Also depends on the rate of the leak. If the oil pan is simply "moist" then maybe just leave it be. Oil is cheap.
    Plants love oil anyways.
    Pretty much what it is. The whole seam is wet, but doesn't drip. And if it does, it must do it once a week because I've never noticed oil stains.
  3. #263 Re: Finalized LIM gasket plans
    get under the car. wipe it clean with a rag, then spray it all down with brake cleaner. then a day or so later see whats wet, and where.
    take the plastic inspection cover off too and clean that. it is wet inside, the rear is likely leaking.
  4. #264 Re: Finalized LIM gasket plans
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    Will degreaser work?
  5. #265 Re: Finalized LIM gasket plans
    Apr 2015
    I like how this was a thread that was supposed to be about final preparations for my LIM gasket and now it's turned into a totally different topic. From what I've heard, this is normal .
  6. #266 Re: Finalized LIM gasket plans
    once a thread has ran its course. it will just take off sideways sometimes lol
  7. #267 Re: Finalized LIM gasket plans
    Apr 2015
    My 180 T-Stat thread did the same thing.
  8. #268 Re: Finalized LIM gasket plans
    once again, it ran its course................
    Edit: just so you know. you can lock a thread you started. bottom left of the reply box.
  9. #269 Re: Finalized LIM gasket plans
    Apr 2015
    I don't see a point so I'll leave it open lol.
  10. #270 Re: Finalized LIM gasket plans
    Apr 2015
    Well no luck on the TB hose. Junkyard didn't have any that I saw. Then again, I only looked in the Pontiac part, will have to check the Buick and Chevy sections later this week. But every GP motor I found didn't have one. Must be a pretty common problem for them to break that easily.
  11. #271 Re: Finalized LIM gasket plans
    i told you how to fix the lines for under 3 bucks. now go re read your own thread lol
  12. #272 Re: Finalized LIM gasket plans
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    you talkin about that plastic vacuum step hose that ubends on both ends ? i used the scotty method. shoved a smaller hose into a bigger hose...it worked !
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  13. #273 Re: Finalized LIM gasket plans
    Apr 2015
    Went to the junkyard again today and found the original Y-hose on a LeSabre. All is good now .
  1. Help With Mod Plans
    By Konvinced89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2015, 10:27 PM
  2. my plans
    By BlackGT97 in forum Off Topic Discussion
    Last Post: 08-10-2011, 12:36 AM
  3. HELP!!! Big Plans...
    By m17davis in forum General Tech Discussion
    Last Post: 10-22-2010, 04:16 PM
  4. MY PLANS for the GT
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 10-28-2009, 11:47 AM
  5. Some new plans for the car.
    By 2000GTP in forum Off Topic Discussion
    Last Post: 10-22-2009, 12:03 AM
