Thread: Fuel Filter
Results 1 to 17 of 17
  1. #1 Fuel Filter
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I'm looking to replace my fuel filter today. On a previous thread, I read not to unscrew the nut from the lines, but from the filter itself because it can twist the line. I know to pull the fuel pump relay to get all the pressure out of the lines. What sizes are the nuts for the male and female attachments? Any other concerns to know about before replacing it. My filter already has the plastic clip on it so I don't need to swap it over.
  2. #2 Re: Fuel Filter
    17mm, 19mm or 21mm maybe??
    I forget the sizes off hand.
  3. #3 Re: Fuel Filter
    Apr 2015
    Are both the male and female nuts the same size, or are they two different sizes? I'd assume the same size, but just checking.
  4. #4 Re: Fuel Filter
    Apr 2015
    21mm I found to be the size. I don't have a 21mm wrench, so I'm gonna use 2 crescent wrenches.
  5. #5 Re: Fuel Filter
    Apr 2015
    Well, one big problem arose. When you look at the threads of the male coupler, you can see they're all rusted. I tried loosening the nut, but it wouldn't budge. I think the thread made its way all the way through into the filter nut. I didn't want to snap the the male end, thus becoming completely screwed. How can I go about loosening the hard line end without it busting off? I had no problem removing the bracket bolt and the quick disconnect side, but it was the hard line end that screwed me over. I was thinking of PB Blaster, good idea?
  6. #6 Re: Fuel Filter
    Like you said before, just hold the hard line and spin the filter off.
    Rust is always going to be a problem. I know many people don't have one, but at work I like to tap the nut end on say the filter with an air hammer. Couple blaps and it can break the rust free without smashing the lines.
  7. #7 Re: Fuel Filter
    Apr 2015
    Well I can't spin the filter, because the bracket is also like rusted to the filter, so I can't spin it very much. I'd have to spin the coupler on the hard line. I couldn't even break it free with two crescent wrenches on each nut. I also don't have any air tools so I can't do your above posted method. The only good thing that came out of doing what I was able to accomplish, was that maybe a 1/4 cup of gas leaked out, total. I couldn't pull the FP relay (lol), so I used a rag and pushed in the Schrader valve on the fuel rail and released the pressure that way.
  8. #8 Re: Fuel Filter
    Work on the bracket and spin the filter.
  9. #9 Re: Fuel Filter
    Enfield, CT
    PB blast the whole thing and muscle it off lol
    Sent from my LG G3
  10. #10 Re: Fuel Filter
    Apr 2015
    Columbus, OH
    Or finally be over it, cut the line and buy a repair kit. What I did because it sprung a pinhole leak at the bend.
    Top Swapped 01 Imp
  11. #11 Re: Fuel Filter
    Buffalo
    Waiting for someone to say " heat it with a torch"
  12. #12 Re: Fuel Filter
    Apr 2015
    Quote Originally Posted by RickyBobby03 View Post
    Man you really want me to destroy my car don't you lol?
  13. #13 Re: Fuel Filter
    Buffalo
    Quote Originally Posted by 01Grand PrixGT View Post
    Me? Never
  14. #14 Re: Fuel Filter
    Apr 2015
    Columbus, OH
    Heat it with a torch.
    Top Swapped 01 Imp
  15. #15 Re: Fuel Filter
    Enfield, CT
    I've done that once and real quick lol. It was on a Ferd.
    Sent from my LG G3
  16. #16 Re: Fuel Filter
    Apr 2015
    A couple of the lines down there are rusty. If a pinhole leak does appear, I'll JB Weld the b*tch shut haha.
  17. #17 Re: Fuel Filter
    Apr 2015
    Columbus, OH
    Look familiar?...
    Top Swapped 01 Imp
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
