Thread: Engine help
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 142
  1. #41 Re: Engine help
    did you have any vibration before the engine pull driving?
    and its not supposed to come apart either, unless you ripped it apart, but i think thats kinda hard to do really.
  2. #42 Re: Engine help
    MINNESOTA
    A little vibration, I didn't pull it that hard
    I pushed it back when I took the wheel bearing off
    How do I know when they go bad, cause I still have the old ones and I can put it back in the car
  3. #43 Re: Engine help
    when bad they vibrate when on the gas, when they first start to go bad its a light vibration when light on the gas, nothing felt when hard on it, but as it wears more they will vibrate bad when your on the gas. you feel no vibration when coasting off the gas.
    if you ever felt a bad U joint on a rwd car its the same thing. only you have more U joints in side the boots of a fwd axle.
  4. #44 Re: Engine help
    MINNESOTA
    Ok, so I can put the old one back on then
    I bought the transgo shift kit and it just arrived yesterday
    I can just follow 02navyblues posting How To Install TransGo Shift Kit 4T65E right
  5. #45 Re: Engine help
    yes, and yes. the kit comes with directions, but the pics are always nice.
  6. #46 Re: Engine help
    MINNESOTA
    Ok
    Thank you
  7. #47 Re: Engine help
    I've used something as simple as a ratchet strap. Looped around the differential (not axle) and hooked onto the top of the firewall.
  8. #48 Re: Engine help
    MINNESOTA
    Thanks
    If it wasn't cause of your "how to" I don't think that I would of tried it
    It wasn't that bad of a job other than working in the heat, that is why I tried to start early in the morning
  9. #49 Re: Engine help
    If you didn't print off the how to ... maybe have it on hand next time. Always.. if you come up against something like the bracket that doesn't say remove oil filter adapter to get bracket, pop online and ask the question. Tons of good people here that know how to get around something like that.
  10. #50 Re: Engine help
    MINNESOTA
    I did print it and even then I forgot the 3 bolts for the torque converter, I think I was getting heatstroke
  11. #51 Re: Engine help
    it was pretty funny, i was putting the engine back in and bill calls me, i pop him on speaker phone and im under the car working on the tc bolts, im clicking the fly wheel with a screw driver and i ask bill so what am i doing now???? he pauses to hear whats going on and says, oh you doing t/c bolts, moving the flex with a screw driver lol even by sound alone he knows what your doing lol
  12. #52 Re: Engine help
    MINNESOTA
    I just want to thank all of the people from the site, for all the help that I have gotten on everything that I needed help with
    And for all the help that I am going to get in the future
    Thanks again
  13. #53 Re: Engine help
    MINNESOTA
    I have the engine on the stand and have the headers off
    This is where the bolt is broken
    Cant see it that good, but the broken bolt is in there
    Can someone tell me what size of drill bit and tap I can use
  14. #54 Re: Engine help
    i would try any type of extractor before drilling and tapping that hole. sears sells these. everyone has a sears near by lol http://www.sears.com/search=easy%20o...lt%20extractor
    most auto parts stores have some kind of extractor as well, run like 8 bucks each size. bring a good bolt, match it up use one thats a bit smaller.
  15. #55 Re: Engine help
    MINNESOTA
    I can get some of those extractors from work, not the hole set but 1 or 2 of them
    Anything else that I should do to the engine while is out
  16. #56 Re: Engine help
    just clean it up good then take it apart to re gasket it. who wants to work on a nasty parts?
    you can also paint it and make it really clean looking.
  17. #57 Re: Engine help
    MINNESOTA
    What kind of paint do I use
    And what am I supposed to pant
    Never painted a engine before
  18. #58 Re: Engine help
    paint it all lol
    started out like this. then all new gaskets and primer and paint.
    i used duplicolor high temp paint and primer.
  19. #59 Re: Engine help
    MINNESOTA
    You didn't sandblast the engine
    That looks nice by the way
  20. #60 Re: Engine help
    i used a wire wheel to get the rust off, sprayed it with brake cleaner and primed it with a whole can, got a light coat and a good coat out of the can.
    yellow was 3 cans in all. but i got 1/2 a can left, and 2 cans of black, and i have more black left over still.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
