Thread: Bigger brakes, R1 concepts, F-Body, Impala???
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Bigger brakes, R1 concepts, F-Body, Impala???
    Feb 2015
    california
    can you run 12" or 13" rotors with stock calipers? Im getting 18 inch wheels that weigh 26 lbs each. 40lbs added weight more when compared to stock rims. Looking at R1 Concepts for rotors as well as W Body package deal for front rotors.
  2. #2 Re: bigger rotors? stock calipers? Help?
    You'd have to get different calipers.
    I believe the impala front brake upgrade or F-body brake upgrade would be what you want to do.
  3. #3 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    do the calipers install the same?
  4. #4 Re: bigger rotors? stock calipers? Help?
    Donating Users timboku's Avatar
    Montgomery, IL
    Fbody calipers are half the weight of stock, dual piston and a 12inch rotor
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    I think i will just get w body front 12" rotor/caliper package a bit more affordable
  6. #6 Re: bigger rotors? stock calipers? Help?
    Montgomery, IL
    Fbodys are 50bucks a pair in jys and new 12inch rotors are 80 bucks on ebay drilled and slotted..way cheaper than wbody store
  7. #7 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    how difficult is installing fbody calipers on a w body?
  8. #8 Re: bigger rotors? stock calipers? Help?
    SE Level Member MM06GT's Avatar
    Jan 2013
    SF Bay Area
    You might want to take a look at this as an option.
    http://www.gpona.com/forums/suspensi...ap-t31615.html
    Silver 06 GrandPrix GT: K&N cai//3" catless DP//SS plog//Rear ported Mani//AL xp 104s//180* TS//ZZP 10.5 wires//TB HS//ZZP 3.2" MPS//E85//50lb injectors//1.9 YT rr//90lb sprs//Impala DP brakes//AF scan gauge//Mini AFR//BLK 18x9 saleen replicas//Overkilled.
  9. #9 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    Isnt the impala a w body? Why does it have a 12 inch rotor? Does that mean the impala has an fbody caliper?
  10. #10 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    do the monte carlos and impalas have a unique caliper from the rest of the w body world?
  11. #11 Re: bigger rotors? stock calipers? Help?
    have you ever changed brakes? pads? rotors? or a line to a caliper? if not you maybe over your head already.
    brakes are about the easiest thing to work on every, but if your lost at installation already, you dont know what your doing to the fullest, do you?
    rule of thumb here, if you take calipers from a car, use it rotors and pads, nothing else. theres is no mix matching of this part and this part. unless you want to crash and die......
    heres a how to for f bodys, pics and parts list too. http://www.regalgs.org/topic/54303-f...brake-upgrade/
    the imp or montie brakes replaces the stock crap too. only those just bolt on and dont need a sleeve or the bracket drilled and taped.
  12. #12 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    Quote Originally Posted by ScottyDoggs View Post
    I just want to upgrade to drilled and slotted rotors. I'm getting bigger 18 wheels that are 10 lbs more than stock each wheel. I'm guessing stock calipers on 12 inch rotors is a no go even if it work because it is dangerous so I'd have to get fbody calipers. I know the w body store offers a package with 12 inch rotors that come with calipers? Not a bad combo? Just trying to upgrade my rotors to and have them compensate for new size and weight. Would standard oem sized and weight drilled and slotted rotors from r1 concepts be just fine or is an inch bigger on the rotors a big difference to upgrade caliper as well?
  13. #13 Re: bigger rotors? stock calipers? Help?
    go find some f body brakes, they come off a 98-02 firebird/camaro. buy the same rotors for those years. the f bodys fit under a 16 wheel aka stock, all but them crosslace wheels. they are a 12 rotor and will help a ton over stock with stock wheels or larger wheels.
    anything bigger is just being flashy lol do they work better some what im sure, but for what the large brakes cost its not worth it unless you have money to burn.
    stay away from the kits, they are charging you 2 times what the set should cost.
  14. #14 Re: bigger rotors? stock calipers? Help?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by silenthaven View Post
    Do you have a GP with factory 11" rotors up front? If so, easiest thing for you is upgrading to 04+ grand prix caliper brackets. You can use your existing calipers, the brackets just move your calipers further from center so you can use a 12" rotor. No switching calipers, no bleeding brakes, just like a regular brake job but you just put different parts back on in the place of stock.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  15. #15 Re: bigger rotors? stock calipers? Help?
    Montgomery, IL
    The wbody kit is just a fbody set up sold in a kit for triple the price.
  16. #16 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    Quote Originally Posted by Impala131 View Post
    i like this idea. how do i get those brackets? would i want to look for 04+ grand prix rotors? or impala rotors? who would have 12 inch rotors that would have the same pattern?
  17. #17 Re: bigger rotors? stock calipers? Help?
    Montgomery, IL
    That's a good idea, but honestly the food caliper is 10times better than the stock set up and lighter...if your gonna get 12inch rotor ls anyway, spend 50 more bucks and get fbody calenders and brackets,..they bolt right on with a 3 dollar adapter sleeve and make a world of difference over stock calipers.
  18. #18 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    Quote Originally Posted by timboku View Post
    tell me with these work? http://www.ebay.com/itm/Power-Stop-R...4ae0d1&vxp=mtr
  19. #19 Re: bigger rotors? stock calipers? Help?
    Montgomery, IL
    Wow that's a great deal but it's only the left side front..you'll need the other side from somewhere and it's already drilled for a woody so you can just reuse your wbody bracket bolts.
  20. #20 Re: bigger rotors? stock calipers? Help?
    Feb 2015
    california
    what vehicles will have a 12" rotor that will fit a 2002 grand prix gtp?
  1. GXP Rotors with C5 calipers?
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2012, 01:11 AM
  2. how to clean rotors & calipers?
    By tcman49 in forum Tires & Wheels
    Last Post: 09-20-2011, 05:01 PM
  3. Looking to get new rotors and painted calipers, how much?
    By tcman49 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2011, 02:20 PM
  4. Want new calipers, rotors, and pads, but...
    By LALAW in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 08:24 PM
