Thread: Best oil filter?
Page 5 of 5 FirstFirst ... 345
Results 81 to 97 of 97
  1. #81 Re: Best oil filter?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Chats
    10438
    Oh and how long would it take for the seal to blow after I did my oil? It's been almost 1 week since I changed it.
  2. #82 Re: Best oil filter?
    Buffalo
    Chats
    7841
    Stab a screw driver through it and turn lol
  3. #83 Re: Best oil filter?
    Chats
    243824
    Quote Originally Posted by 01Grand PrixGT View Post
    Well I tried loosening it and I didn't want to go much harder as I was afraid I was gonna break the filter. Looks like I'm gonna have a fun time 3000 miles later . How tight do they have to be when the seals blow? I'm probably gonna have to buy one of those removers that crush the filter while removing it lol. F*ck me.
    if its not blown out leave it alone. when you take it off tho put your filter wrench all the way to the top of the filter, as that is the only solid metal part, that top 1/4 inch of the filter.
    if you use the middle of the filter it will crush and leak and not come off.
  4. #84 Re: Best oil filter?
    Apr 2015
    Chats
    10438
    Quote Originally Posted by RickyBobby03 View Post
    Well it doesn't need to be removed yet so I'll pass. I read sticking a low profile object, like a razor blade, in between the gasket and the block to break the seal. I'm not gonna stress it until it starts leaking. Probably not the smartest idea, but I highly doubt the oil will all leak out in 30 seconds so I'll just check it every time I drive just to make sure it isn't leaking.
  5. #85 Re: Best oil filter?
    Apr 2015
    Chats
    10438
    Quote Originally Posted by ScottyDoggs View Post
    Would it have blown by now? Or does the pressure need to build up for a while before it goes.
  6. #86 Re: Best oil filter?
    Chats
    243824
    if its on there a week its fine. leave it along,
    and for the record never stab it with a screw driver, that never works well for any one. its a huge fail.
    the best are the pliers type you grip that top part where the seal is and it always comes off with ease.
    this f er will never let you down, ever!
  7. #87 Re: Best oil filter?
    Apr 2015
    Chats
    10438
    I'll probably have to buy one of those before I change it 3000 miles later. I'll just periodically check for leaks around the seal and if it's leaking, change it.
  8. #88 Re: Best oil filter?
    Apr 2015
    Chats
    10438
    I'll buy the Harbor Freight version . Cheaper than the name brand one haha.
  9. #89 Re: Best oil filter?
    Buffalo
    Chats
    7841
    f yeah it does I don't fck around
  10. #90 Re: Best oil filter?
    Apr 2015
    Chats
    10438
    Hey RickyBobby03, this ones for you...
  11. #91 Re: Best oil filter?
    Feb 2013
    Missouri
    Chats
    1970
    Quote Originally Posted by Bronco Boy View Post
    Warranty applies to mfg defects. I would think in this case, the counter guy has made an error and your warranty should stop when he gets caught and or fired. LOL
    He works at the part store...
  12. #92 Re: Best oil filter?
    GT Level Member atj8's Avatar
    Midwest
    Chats
    51
    98 GTP Gen v 2.8,FSIC,xpcammed,SD headers,CAI,CORNFEED,TIMBOKU TUNED
    04 Comp-g Turbo,Cornfed, TIMBOKU tuned
  13. #93 Re: Best oil filter?
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Chats
    841
    When i change the oil, i tighten it as much as possible with hand, fill 1/2 with oil, put oil around the top, then give it a 1/4-1/2 turn extra. The k&n filters have a nut on the end so easy on, easy off..I still use the oil wrench from habit, more than how much easier it is to use a socket, its just as quick, I just wanted a nice oil filter.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  14. #94 Re: Best oil filter?
    Apr 2015
    Columbus, OH
    Chats
    246
    Just stick a screw driver through the side and twist. Its pretty much how I've gotten every one off that went through a quick lube. And tightening, I've always took it 1/2-3/4 turn past the point that the rubber first meets the metal seat. Never had a leak and it always comes off easy.
    Top Swapped 01 Imp
  15. #95 Re: Best oil filter?
    Enfield, CT
    Chats
    8962
    X3
    Sent from my LG G3
  16. #96 Re: Best oil filter?
    Jan 2021
    Ohio
    Chats
    NAPA Gold is a rebranded (but NAPA) WIX.
  17. #97 Re: Best oil filter?
    Nov 2021
    Reading, PA
    Chats
    I don't know if it is still the truth but at one time Mobil 1 filter and K&N oil filter were the same filters with different casings.
    K&N is also the manufacturer for NAPA Gold
  1. Air Filter?
    By RideMr2 in forum General Tech Discussion
    Last Post: 10-23-2010, 09:16 PM
  2. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  3. SLP CAI vs K&N FILTER
    By JB381 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:20 AM
