Thread: 2006 3.8 block with a top swap Gen 3?
Results 1 to 8 of 8
  1. #1 2006 3.8 block with a top swap Gen 3?
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    I was wondering if A. My intense PCM would be messed up if I used the block from an '06, as the engine in my 2000 GP popped. B. Would I be able to put the L67 balancer on it to run both belts? All I'm looking for is a block, and I found a whole engine that needs head gaskets for $250. Will it work?
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  2. #2 Re: 2006 3.8 block with a top swap Gen 3?
    are you already top swapped? if so its fine. swap any engine sensors over that dont match the cars plugs and off to the races you go.
  3. #3 Re: 2006 3.8 block with a top swap Gen 3?
    Oct 2013
    Iowa
    I was about to top swap the old engine in the 2000, but it blew before I started. Could I just swap the wiring harness and stuff over to the '06 block then?
  4. #4 Re: 2006 3.8 block with a top swap Gen 3?
    you can. you just swap the block in. but if your intense pcm is not for a top swap you'll want to get that set up.
    its what i just i did pretty much. used a l36 block in place of my l67 block. its a bottom swap in this case cause my car came supercharged.
    i also had to get a top swap tune.
  5. #5 Re: 2006 3.8 block with a top swap Gen 3?
    Oct 2013
    Iowa
    I have a top swap tune from intense already, but thanks for the help Scotty. Hopefully she'll be up and running this month.
  6. #6 Re: 2006 3.8 block with a top swap Gen 3?
    it will all work like you planned for the l36 in your car. its just another n/a bottom end.
    its easier to build the engine on a stand too vs doing the top swap in the car. so its kinda a win as long as it has to come out.
    get the new block all set up with your top swap parts and drop it back in. good time to replace all the gaskets if its oiled up mess already.
  7. #7 Re: 2006 3.8 block with a top swap Gen 3?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by ScottyDoggs View Post
    its easier to build the engine on a stand too vs doing the top swap in the car. so its kinda a win as long as it has to come out....
    I can only imagine. In hindsight, I wish I had just pulled the engine first on mine.
    Top Swapped 01 Imp
  8. #8 Re: 2006 3.8 block with a top swap Gen 3?
    Donating Users timboku's Avatar
    Montgomery, IL
    Only difference is the 06 l26 will be an aluminium oil pan so you need to grind it a little to get the 2000 engine mount on it..everything else bolts up..I have a l26 bottom end and a l67 upper.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. 2006 Grand Prix GXP Rim Swap
    By Lwf23 in forum General Grand Prix Discussion
    Last Post: 05-03-2015, 04:20 PM
  2. New member from NY, block swap question, 04 CompG
    By Tom0247 in forum Introductions/Noob Questions
    Last Post: 09-29-2013, 06:29 AM
  3. Have 2006 L26 Top Swap Questions
    By mram10 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2012, 05:35 PM
  4. 2006 3800 NA short block? LaCrosse
    By sseilmnop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2011, 06:38 PM
  5. Whole engine block kinda Swap
    By mikeh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-19-2009, 12:30 AM
