Thread: Block part number locations and such.
Results 1 to 3 of 3
  1. #1 Block part number locations and such.
    GXP Level Member
    Mar 2015
    Tomball
    So I'm looking for the part number for the block in my car and was not able to find it. I did fine these though:
    oil pan part number:
    GM 12581549
    block: DR side rear side next to freeze plugs
    3800
    Series
    nothing else in that area.
    found a tag with a bar code on it above the bar code was BFL-R the bottom was difficult to read the first 5 digits but got 10RFL B0351736
    looked on the web but couldn't find anything.
    Thanks,
    Jeff
  2. #2 Re: Block part number locations and such.
    I'm pretty sure all the blocks are the same, all series 2 and 3 motor will carry the same series 2 stamp on the block because it was not worth the cost to make a new mold.
    If you are looking for like internal differences, I'm pretty sure you have to crack open the motor to tell. I know the connecting rods are different between the L67/L36 and L32/L26 but I don't know exactly what to look for between L32 and L26.
  3. #3 Re: Block part number locations and such.
    GXP Level Member
    Mar 2015
    Tomball
    Mine didn't even say series 2 or 3 just 3800 then under it series. Block numbers are the same for both huh? Man that makes things hard.
    Found a LKQ sticker on the transmission.
    curiouser and curiouser....
  1. Looking for a 04+ part number
    By 2003 SSEi in forum General Tech Discussion
    Last Post: 12-13-2014, 10:30 AM
  2. Part number
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2014, 10:24 PM
  3. MAF part number for 02 gtp
    By jonygtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2012, 04:44 PM
  4. locations on 3800 Series engine block
    By ibduhone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 12:33 PM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
