Thread: Harmonic balancer/crankshaft
Results 1 to 18 of 18
  1. #1 Harmonic balancer/crankshaft
    Jun 2015
    Missouri
    I'm trying to replace my crankshaft position sensor on my 2000 Pontiac Grand prix and in doing so obviously need to take off the harmonic balancer to get to it. I've got the huge bolt off and rented the pulley system from Autozone. I had to go and buy the right bolts and washers to fit into the harmonic balancer (hb). The pulley kit I rented came with a cone shaped metal piece that goes on the end of the black pressure screw to push out the hb. In my stupidity and ignorance I noticed that the cone was too big but didn't know it wasn't supposed to be so like an idiot I started tightening it down and now have gotten that piece stuck in the hb...and it won't budge out for anything. I just need an alternate way to get the thing (the hb) off as I need to replace this sensor so that I can drive this car to work. Thanks ahead of time for any feedback.
  2. #2 Re: Harmonic balancer/crankshaft
    GXP Level Member
    Mar 2015
    Tomball
    Remove the puller part and just use the threaded rod, place it back into the cone that is stuck and wiggle it back and forth unless it is in too far you should be able to get it out. Then use the flat piece that comes with the kit instead of the cone, thread the bolt back into the crank and leave about an 1/8" clearance and put everything back together (the puller) and as you pull the balancer back up the threaded rod then the bolt until you can pull it off.
    Jeff
  3. #3 Re: Harmonic balancer/crankshaft
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    If you just thread the rod as far as it'll go into the crank (without the cone or anything), it'll be just enough to pop the balancer off. Just make sure you got it going in straight. I have the same puller, not sure how many times I've pulled balancers with it using this method.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  4. #4 Re: Harmonic balancer/crankshaft
    Jan 2009
    Tallahassee, FL
    It it's anything like my puller the center big bolt is actually the same thread at the crank bolt. Mine lost that center cone long ago before I got it. I put a socket extension into the crank then used the puller which pushes against the extension. If you can't get it to release then use a pair of vice grips on the flywheel to keep the motor from spinning and loosen the bolt.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: Harmonic balancer/crankshaft
    im a pro at that balancer removal now lol i got a load of the bolts too. any one needs some holla. i had to buy a bag of 25 bolts.
  6. #6 Re: Harmonic balancer/crankshaft
    Bastard Reptile's Avatar
    Kansas City, MO
    I always use a 10mm deep socket into the hole, That way you don't have to worry about the puller threading into the crank.
  7. #7 Re: Harmonic balancer/crankshaft
    Quote Originally Posted by Reptile View Post
    Ditto^^^ super easy this way.
  8. #8 Re: Harmonic balancer/crankshaft
    I would try hitting it from all directions and see about loosening it up. Likely it's too hard to drill.
  9. #9 Re: Harmonic balancer/crankshaft
    hangover park IL
    ive had one of these so badly wedged we had to use a torch to blow out the puller nose to get the damper off and toss on a new one (torch damage to old one)
    ~James~ Psychotic Gearhead
  10. #10 Re: Harmonic balancer/crankshaft
    Apr 2015
    Columbus, OH
    Getting it off was no problem, but getting that stinkin bolt stretched to 70° (think it is) was a royal pita. Could only get about 15° at first. Finally got to 60° out of pure rage - only had a 8" extension for my 1/2" breaker bar.
    Thought my floorpans would fall off if I didnt torque it right. Then I learned most don't even bother to TTY them....
    Top Swapped 01 Imp
  11. #11 Re: Harmonic balancer/crankshaft
    mine is air gun zapped on. and its a weak air gun lol
    i must say even a crappy air gun makes this job so much easier. cant imagine taking it off by hand. or back on for that matter lol
  12. #12 Re: Harmonic balancer/crankshaft
    Apr 2015
    Columbus, OH
    I've never used an air gun in my life, no lie. Only time I really wished I had one was when taking axle nuts off. Probably don't realize what I'm missing.
    Top Swapped 01 Imp
  13. #13 Re: Harmonic balancer/crankshaft
    If you ever touched one, you'd never give it back.
  14. #14 Re: Harmonic balancer/crankshaft
    air guns are not for every job, but when its a long ass bolt thats tight as hell. the air gun makes quick work of it. like the puller drive bolt. balancer is off a minute after the bracket is bolted on the balancer.
  15. #15 Re: Harmonic balancer/crankshaft
    Jan 2009
    Tallahassee, FL
    I think I've only ever used an air gun once on my car and that was to get the crank bolt out and back in. Everything else has been the el manual method. I just prefer it that way.
    77 Morris Garage B
  16. #16 Re: Harmonic balancer/crankshaft
    GXP Level Member
    Mar 2015
    Tomball
    Lol my gun wouldn't cut it I had to use the starter. Lol.
  17. #17 Re: Harmonic balancer/crankshaft
    Apr 2015
    Columbus, OH
    Quote Originally Posted by J57ltr View Post
    Starter works every time. That's how I've always broke loose HB bolts.
    Top Swapped 01 Imp
  18. #18 Re: Harmonic balancer/crankshaft
    Cibolo, TX
    Never used anything but a 1/2" breaker bar with a cheater pipe myself.
  1. Harmonic balancer
    By dezebe1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2014, 10:19 PM
  2. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  3. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  4. Harmonic Balancer Crankshaft Pulley
    By sicayan in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-21-2011, 11:10 AM
  5. Harmonic, Balancer, Crankshaft, Sensor
    By tboy160 in forum General Tech Discussion
    Last Post: 09-12-2010, 10:46 AM
