Thread: antifreeze leak
Results 1 to 11 of 11
  1. #1 antifreeze leak
    Jun 2015
    forest city
    I am not sure I am in the right spot. I have an 07 grand prix with 146000 miles on it. I am losing antifreeze but cannot find where it is going. The oil is fine but I do get a smell after driving it. Also when riding in it i can hear the water slushing around in it. Where should i start? Thanks for any help.
  2. #2 Re: antifreeze leak
    slooshing sound is air in the heater core. if the floor is wet the core is leaking.
    if the floor is dry you need to get under the car and trace the puddle back to the source.
  3. #3 Re: antifreeze leak
    Jun 2015
    forest city
    I cannot find a leak anywhere. It does not make it to the ground if there is one.
  4. #4 Re: antifreeze leak
    get a pressure tester and pressurize the rad, the gauge will show a leak if it looses pressure.
  5. #5 Re: antifreeze leak
    St. Louis
    Check the radiator itself, especially where the plastic side tanks are crimped to the alum. core. Could also be a coolant elbow.
  6. #6 Re: antifreeze leak
    SWPA
    I'm betting on the culprit being the water pump. When mine was leaking I was going nuts trying to find the leak. I finally lucked out one day and saw it seeping while the car was running and verified the water pump was shot by popping the belt off and feeling the play in the water pump pulley.
  7. #7 Re: antifreeze leak
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Mother inlaws 02 GPGT had the coolant slowly leaking out. Couldn't find it anywhere. Rented a pressure tester from vato zone. Put some pressure on it and found the hose clamp on the upper radiator hose wasn't tight. Never noticed it because it would hit the trans housing and burn off. Never had a problem since tightening it.
    The leak could be anywhere.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  8. #8 Re: antifreeze leak
    GTP Level Member
    Aug 2012
    st louis park, MN
    I once had a slow coolant leak between the interface of the block and thermostat housing. There must have been some imperfection and since it was metal to metal it would slowly leak out and evaporate on the engine. I just used some permatex gasket/sealant and it's been great since.
    Could be a variety of places like the others have stated.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  9. #9 Re: antifreeze leak
    Depending on what coolants in it makes it easier to spot.. For example I use green and I can 9/10 spot it pretty quickly. If you can't find it that way.. Pressure test it and that should make it easily visible.
    04 Comp G.
  10. #10 Re: antifreeze leak
    Apr 2015
    dont use that pour in fix stuff. that hurts the gaskets and doesnt really work good plus it gunk's up the system. do a pressure test. if you smell out of the back ed it might be the lower intake gasket. i had a very small leak on mine and it only smell anti freeze going 60 to 70mph. look all around in lower intake gasket too. make sure i had to change my lower intake gasket at 144,000 miles so your might be do
  11. #11 Re: antifreeze leak
    ever use blue devil? didnt think so, it works if you need it. its all thats holding my engine together.
    if it needs lim gaskets thats another story tho.
  1. LIM antifreeze leak
    By 2004GrandPrixGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 10:49 PM
  2. antifreeze leak question
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:37 PM
  3. antifreeze leak
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2011, 08:50 AM
  4. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  5. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
