Thread: Service ABS/Stability/Traction/Brake System
Results 1 to 8 of 8
  1. #1 Service ABS/Stability/Traction/Brake System
    SE Level Member Perma's Avatar
    Southwestern, ON
    So my '06 Grand Prix GT started flashing all of these today. I hooked up my scanner and the three codes that came up are C0550, C0450 and C0898. Has anyone experienced this and have any ideas?
    Thanks in advance!
    2006 Grand Prix GT
  2. #2 Re: Service ABS/Stability/Traction/Brake System
    St. Louis
    Could be a bad wheel bearing, or the EBCM. Clean/check all the connectors at the hubs, clear the codes and see if it comes back. If it does then you need to have the EBCM rebuilt (the ABS control module).
    C0550 is an internal malfunction in the ABS/traction control module
    C0450 Steering Assist Control Solenoid/Motor/Actuator Circuit = EBCM
  3. #3 Re: Service ABS/Stability/Traction/Brake System
    Apr 2015
    Brooks
    Are these specific to vin numbers?
  4. #4 Re: Service ABS/Stability/Traction/Brake System
    St. Louis
    No, they are OBD codes. Should be universal.
  5. #5 Re: Service ABS/Stability/Traction/Brake System
    May 2015
    Sorry to bug new to this how do I ask my own question
  6. #6 Re: Service ABS/Stability/Traction/Brake System
    Apr 2015
    Columbus, OH
    Quote Originally Posted by mpiece530 View Post
    You just did
    Top Swapped 01 Imp
  7. #7 Re: Service ABS/Stability/Traction/Brake System
    St. Louis
    When you open the forum you want to be in (i.e- General GP Discussion, Transmission, etc.) there is a button at the top left of that forum that says "Post New Thread". Once you click that you will be starting your own new thread in that forum.
  8. #8 Re: Service ABS/Stability/Traction/Brake System
    May 2015
    FORT WAYNE, INDIANA
    In response to original question we had a right rear hub replaced on our 04 GP GT 5 years ago because bad sensor and steering was hard especially in parking lots. Last few years we would hit a bump in the road and trigger the same loss of the elec. traction control. However after parking and restart sometime later it would be back to normal and this ALWAYS happened in the summer, never in winter like you would expect with all the snow and ice on the roads causing uneven driving surface.
    To this day it has probably been a year since this last happened and brakes and steering assist are normal.
    So to me its like an on and off again harness issue, at least in our case. The first time was definitely a RR sensor issue.
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. Traction Control Off / Stability Control Off / Service ABS System
    By compro in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2012, 09:37 AM
  3. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  4. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  5. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
