Thread: c0035
Results 1 to 12 of 12
  1. #1 c0035
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Ive replaced all 4 wheel bearings, driver cv axle, tie rod ends, brake pads and rotors on this 07 gp base. 134k miles, hit a "embankment" about a year ago, and 500 miles ago.
    Still getting c0035 right front speed circuit, im pretty sure car hit on the front left side, the axle must of took a nice jolt, broke the boot off and was throwing grease everywhere down there on driver side.
    Do i need to replace the abs cord from engine to where it plugs into the hub? My tpms is going off too, all say 0. I need to calibrate it, but i need a working keyfob to do that, and my keyfob i have for the car is not programmed.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: c0035
    St. Louis
    Probably time to get under there and visually check the wiring. Might just be cut/loose. Also check the plug itself. Could just be dirty.
  3. #3 Re: c0035
    Quote Originally Posted by FordMan77 View Post
    This
    Grab a can of electric cleaner and clean the plug.. Then clear the code if your able too and see if it comes back. You can also unhook the battery too for a few minutes.
    04 Comp G.
  4. #4 Re: c0035
    Apr 2015
    Columbus, OH
    There is a tsb for the front speed sensor wiring. The replacement wire is longer and fastens to control arm differently to prevent it from being stressed. I'm dealing with similar issue.
    Top Swapped 01 Imp
  5. #5 Re: c0035
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    i had the c0035 code and a new left front abs harness fixed it . cost about $25 on amazon.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  6. #6 Re: c0035
    Aug 2012
    Brainerd, MN
    Is it hard to put a new harness in? Does anyone have a picture to where it actually goes to? Do i have to wire it all up and all that fun stuff? I am going to look at it next week, my 01 gp is playing garage queen and is waiting for the right color paint for the roof rails.
  7. #7 Re: c0035
    Apr 2015
    Columbus, OH
    It clips in both ends. Easy swap. Will take longer to remove the wheel.
    Top Swapped 01 Imp
  8. #8 Re: c0035
    Aug 2012
    Brainerd, MN
    The one that i got had two open wires at one end, and the plug that plugs into the wheel hub. I tried to follow the cord but didnt see a plug on the other end at all.
    I noticed the cord was damaged in one point, so i cut it a little bit past that and tried to splice the new one onto it, and no dice. Still got the speed sensor c0035 code come up.
    I noticed when doing driver cv axle, the driver strut boot that goes over shock was all shrivvled up and dried out. I can bring it to my shop and have them align the car and see exactly whats wrong with the cord for wheel bearing, but i dont want to have to align the car twice. Lower control arms look a little bad, and rear strut mounts are making noise. Its 70$ for two front lower control arms with ball joints from my supplier. I havnt looked into 4 quick mount struts, but im thinking about 250-300$.
  9. #9 Re: c0035
    Aug 2012
    Brainerd, MN
    Heres a pic to where it goes from the wheel hub, im a little confused, there is a plug down there but it doesnt look like its coming from the abs cord.
    I have my finger on the one that is coming from the wheel hub.
  10. #10 Re: c0035
    Dec 2014
    Maryland
    the old harness should have had a clip at both ends . i just cut the clip off and spliced them together. if yours didn't have a clip at the end toward the radiator then it was probably already replaced once. use a multimeter and check the resistance and compare it with the other side.
    watch this video
    https://www.youtube.com/watch?v=KFQphWamcjQ
  11. #11 Re: c0035
    Aug 2012
    Brainerd, MN
    Ok ill take a look at it in the morning.
    I actually did notice that you can see a couple inches down theres a wire that goes up, could that be the other end of the plug for abs?
  12. #12 Re: c0035
    pretty sure only the pass side has a plug, its near the balancer on the side of the inner fender. the driver side you need to cut the wire and splice in the new harness.
