Thread: Anti-Freeze/dexcool
Results 1 to 16 of 16
  1. #1 Anti-Freeze/dexcool
    Apr 2015
    What Anti-Freeze are you people using? Should i get rid of Dex-Cool when i get the intake gaskets replaced? i hear horrible stories about dex-cool.
  2. #2 Re: Anti-Freeze/dexcool
    Massachusetts
    Hi LifeDeerHunter,
    I've been wondering the same thing myself. Hopefully someone with some experience in this area will chime in. I'd be interested to hear the answer.
  3. #3 Re: Anti-Freeze/dexcool
    I run green, some run prestone etc
    Dexcool is fine as long as you keep up with your flushes and make sure there's no leaks in your system. Dexcool tends to gunk up if airs introduced to the system or if you go without doing routine flushes..
    Choice is really up to you
    04 Comp G.
  4. #4 Re: Anti-Freeze/dexcool
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    You'll need to flush your system several times to get the dex out, but it's worth it to be rid of such a vile coolant. A thorough flush is a good thing to do on an older car, anyways.
    http://dex-cool.net/
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  5. #5 Re: Anti-Freeze/dexcool
    Apr 2015
    Burtonsville, Maryland
    Dexcool is awful .even when air doesn't get into the system it still turns to crap. Do your self a favor and flush out all the details and run green or yellow. Every GM car that I've owned has gotten that flush, the one that didn't had a continuous issue with the heater core clogging . I wanna meet the guy that decided that all gm cars should have dex cool and remove his genitalia with a dull knife
  6. #6 Re: Anti-Freeze/dexcool
    Cibolo, TX
    I'll hold him down for you while you do it.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  7. #7 Re: Anti-Freeze/dexcool
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Courtesy of Scotty:
    how to flush coolant.
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    done.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  8. #8 Re: Anti-Freeze/dexcool
    even when i dont post....i post lol
  9. #9 Re: Anti-Freeze/dexcool
    Apr 2015
    Lol ^^^
  10. #10 Re: Anti-Freeze/dexcool
    Apr 2015
    thanks. i am going to tell him to use normal anti-freeze
  11. #11 Re: Anti-Freeze/dexcool
    Jul 2010
    Coquitlam,BC,Canada
    My car was green when I bought it 5 years ago; saved me from having to change it.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Anti-Freeze/dexcool
    Mar 2015
    Tampa, FL
    I run mopar HOAT coolant in my car cause it was free
  13. #13 Re: Anti-Freeze/dexcool
    Apr 2015
    Fl
    I also run green and have no complaints about it.
  14. #14 Re: Anti-Freeze/dexcool
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I run green in all the grand prixs ive had. My g6 has dexcool, i flush the radiator and coolant tank soon as i get a car, the dexcool will eat at the intake gaskets.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  15. #15 Re: Anti-Freeze/dexcool
    Apr 2015
    Columbus, OH
    I switched to green. But they were talking about this on "Under the Hood Show" podcast. They said that there was definitely issues with the old dex, but the newer stuff has been corrected. Something about the organic stuff in it.
  16. #16 Re: Anti-Freeze/dexcool
    Apr 2015
    Yeah sure they fixed it, just like that new grape scent gm gear oil lol
  1. Anti Freeze Leak?
    By 02prixgtp in forum Introductions/Noob Questions
    Last Post: 05-09-2014, 08:07 PM
  2. What part is this? (Anti-Freeze Leak)
    By Bologna in forum General Tech Discussion
    Last Post: 12-21-2011, 08:03 PM
  3. Replies: 2
    Last Post: 08-04-2011, 08:58 AM
  4. Anti Freeze Leak
    By JB381 in forum General Tech Discussion
    Last Post: 02-26-2010, 09:00 PM
  5. Oil "Leak"/Anti-freeze dump
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 08:06 PM
