Thread: Bad Wiper Motor?
Results 1 to 6 of 6
  1. #1 Bad Wiper Motor?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    My wipers seem to be acting up. Let's start off by saying what they do correctly: the Mist function works properly, the switch for the fluid works fine, the intermittent settings work (only some), and now the problems. Once you get to the second to last intermittent setting (shorter of the lines), the wipers will act as they're on the High setting. Moving down to the last intermittent setting does nothing either, same speed as before. Moving the wiper setting into the High and Low sections does nothing either. Low and High will be the same speed as before. I'm 99% positive the wipers aren't supposed to work this way. Is this a bad motor or do you think its a relay? Clueless.
  2. #2 Re: Bad Wiper Motor?
    St. Louis
    Could be the multifunction switch.
  3. #3 Re: Bad Wiper Motor?
    Apr 2015
    Never heard of it. Is that something I can replace, or is it part of the whole wiper, blinker, cruise stalk?
  4. #4 Re: Bad Wiper Motor?
    St. Louis
    Yep, its the stalk that controls the wipers, highbeams, cruise. Hence multifunction.
    Should be replaceable. Never really had to but have seen it mentioned here. Try a quick search for multifunction replacement. I'm sure something will turn up. If not, then I'm sure we can help.
    Here's one that should start you in the right direction should you need to replace it--> http://www.grandprixforums.net/threa...unction+switch
  5. #5 Re: Bad Wiper Motor?
    Apr 2015
    Dang that seems like a lot of work to remove the stalk. Is there anything else that could cause the problems listed above? Is there a wiper relay in the engine fuse box or something?
  6. #6 Re: Bad Wiper Motor?
    Jan 2014
    AR
    The wiper delay module is mounted underneath the motor. Can't really even see or unplug it until you have the wiper transmission assembly out, but it is a common source of problems like yours. Replacement units have a more durable circuit board. First time doing this job should take about an hour, getting the trans ass'y out of the opening in the cowl was the toughest part for me. Part is around fifty bucks.
  1. Wiper Motor?
    By BrewMaster in forum General Tech Discussion
    Last Post: 02-11-2012, 01:20 PM
  2. Windshield Wiper Motor
    By gpgt98 in forum General Tech Discussion
    Last Post: 12-31-2011, 12:13 AM
  3. wiper motor
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2011, 01:19 PM
  4. Wiper Motor Location 07 GT
    By 07GTTX in forum General Tech Discussion
    Last Post: 09-24-2008, 07:33 PM
