Thread: 02 -04 trans swap
Results 1 to 3 of 3
  1. #1 02 -04 trans swap
    Apr 2015
    Charlotte, MI
    I pulled a trans from an 02 gt and put it in my 04 gt. I cant get it to crank. is there a park sensor switch some where that i cant find or has anyone had same problem?
  2. #2 Re: 02 -04 trans swap
    Donating Users timboku's Avatar
    Montgomery, IL
    02s are not compatible with an 04, the valve body and wiring is diffeferent.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: 02 -04 trans swap
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    In order to use an 04 trans on an 02, you would need to use a 2003 GT ECU (the trans electronics, and ECU drivers are different 98-02 and 03+), and swap the external range switch from the 02 trans onto the 04.
    That should get you up and running.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  1. top swap and hd trans
    By xcwilli11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2014, 11:04 AM
  2. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  3. Trans swap
    By 443pearl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-01-2012, 09:56 PM
  4. Trans swap ???
    By cogsracing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 12:40 PM
  5. Trans Swap
    By Terry102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2011, 08:38 PM
