Thread: 2005 GTP engine power loss (No codes and no errors on the DIC)
Results 1 to 2 of 2
  1. #1 2005 GTP engine power loss (No codes and no errors on the DIC)
    Feb 2014
    Parma Ohio
    Seeing if anyone has any idea before I give up and sell my car, was up for sale then decided to keep it now its having a random power loss so I want to get rid of it if I cant figure it out.
    This is a very, very intermediate problem, my car will have a huge power loss until I shut my car off and restart it, I can shut it off for one second and start it then its back to normal. Its been doing this about once a week
    Also once in awhile if I use the remote start, it will start then stall, I then try it again then in will start and stall once again, or it will keeping cranking till it starts(then have to start it with the key since it only allows two attempts before its disabled), but it never has a problem starting with the key only remote start
    there's 0 pending codes, 0 history codes and 0 present codes
    here's what im guessing it could be
    1. Throttle body
    2. PCM
    3. EGR valve
    4. clogged cat (but shouldn't it do it all the time)
    5. fuel filter (but was told 05 doesn't have a external filter, been too lazy to check if it does or not)
    any input will be appreciated thanks in advance
  2. #2 Re: 2005 GTP engine power loss (No codes and no errors on the DIC)
    GXP Level Member
    Mar 2015
    Tomball
    05' doesn't have an external filter.
    I would check for vacuum leaks, I just bought an 05' and had huge issues with the car running great then it would just lay over, it also go to the point where I started getting a P0068 and I found that the vacuum lines that run from under the snout to to the MAP on the firewall side and the boost solenoid on the radiator side were all in bad shape. I got the car running a lot better now, but I still have an issue.
    Jeff
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Reduced engine power 2 codes
    By davidadams in forum 04+ Specifics
    Last Post: 02-16-2014, 08:13 PM
  3. Engine Power Loss
    By Israel Toledo in forum General Grand Prix Discussion
    Last Post: 06-19-2012, 08:43 AM
  4. Engine Power Loss at Higher RPM
    By GP Modder in forum General Tech Discussion
    Last Post: 01-16-2012, 10:21 AM
  5. Engine stalling and loss of power while driving
    By LePrix in forum General Tech Discussion
    Last Post: 09-01-2011, 08:32 AM
