Thread: Upper Intake Manifold Repalcement
Results 1 to 8 of 8
  1. #1 Upper Intake Manifold Repalcement
    Massachusetts
    For those that have done this what aftermarket or OEM upper intake manifold would you recommend using? I'm looking for longevity. Replace it once and be done with it. I picked up a Dormans, but before I use it I want to know that it will stand the test of time. If there is something better I'd appreciate knowing. Thanks.
  2. #2 Re: Upper Intake Manifold Repalcement
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    I think you can swap a Series III on there? Someone correct me if I'm wrong, but I feel like I've seen or heard people do that. Those are metal so they won't warp and never have to worry about them, but I'm not sure if it can be done.
    '01 GT, OnStar antenna removed, GT emblem on grille, PONTIAC bumper inlay, engine cover and insulator removed, polished stock exhaust tips, 17" Bullitt rims
  3. #3 Re: Upper Intake Manifold Repalcement
    Dormans work just fine, have one on the sisters bonneville for over a year now.
    It's what we buy at my work too.
    Hopefully you are doing the lower intake gaskets at the same time.
  4. #4 Re: Upper Intake Manifold Repalcement
    Massachusetts
    Absolutely doing the lower intake gaskets at the same time! Want to get rid of the junk plastic ones that are there. Will also replace the plastic bypass coolant elbows with aluminum ones, new t-stat and o-ring, and new o-rings on the fuel injectors. Anything I've missed? Thanks.
  5. #5 Re: Upper Intake Manifold Repalcement
    If you want your manifold to last, here's the info that most don't realize about why there's an issue.
    http://www.grandprixforums.net/threa...hlight=failure
    Personally..I don't replace the manifold. I modify the LIM to plug the coolant ports. Then the issue can never happen.
  6. #6 Re: Upper Intake Manifold Repalcement
    Massachusetts
    Well Bill, that does sound like the way to go to preclude that from ever happening. No coolant to the upper, no leak to the lower. I guess that is what I should really be looking at doing. I'm in Southeastern Mass, so if you haven't had problems with icing being in the Springfield area then I shouldn't either. And I never have to worry about a coolant issue from that area of the car, ever. Sounds like a winner. Thanks!
  7. #7 Re: Upper Intake Manifold Repalcement
    I know guys in upper Canuckland that never had icing issues.
  8. #8 Re: Upper Intake Manifold Repalcement
    Massachusetts
    Okay, so get on down here and let's hit it and get this thing fixed!
  1. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  2. Upper Intake Manifold blew apart
    By forumsKDC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2013, 11:10 PM
  3. upper intake manifold?
    By Akuch26 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 01:22 AM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
